Question about Pride Mobility Products Health & Beauty
Lights work no power
Green light on battery on red light nothing, no power. lights working otherwise dead do you know what is wrong pride mobility scooter victory
  • Pride Mobili... Master
  • 1,138 Answers
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
Posted on Aug 03, 2015
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
  • 175 Answers
SOURCE: Having trouble with a 3-wheel Pride Mobility
Check that it is unplugged from the charger. Then check the freewheel lever to ensure it is in gear by placing it out of gear first, then placing it firmly in gear. Do this while the key is OFF. Wait three seconds, then turn back on and it should go.
If it doesn't, and you are sure it's in gear and unplugged from the charger, you should be getting a fault code flashing on the charger display. Consult your owners manual to determine the fault and proceed as recommended.
Here's a link to the owners manual if you've lost yours. Good luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Victory_om.pdf
Posted on Jul 11, 2009
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
  • 19 Answers
SOURCE: I own a pride victory scooter that stopped
possible blown fuse or breaker needs to be reset.
Posted on Sep 15, 2009
uxair shah
  • 812 Answers
SOURCE: I have no manual for my Pride Victory 4 wheel
Hello i hope u 'll be fine.... thanks for using fixya.
You can easily get the manual for Pride Victory 4
Download it and Enjoy
You can also see lots of effective information of your product from this.
  • Manual is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u. Best of luck
Please do rate if it is helpful
THANKS
Posted on Mar 02, 2010
Why does green light on charger stay on?
Most pride chargers show up the green light when batteries r charged...when charging u should have a red power led & an orange led ...hope this helps
Jan 07, 2016 | Pride Mobility Products Go-Go Elite...
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
Ed light flashing
I think you might try the reset switch on the battery pack
Apr 24, 2013 | Pride Mobility Victory 3 Wheel Electric...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
The horn will beep, but the power meter shows no power on my pride go-go elite.
It sounds like the batteries have gone bad and need to be replaced. Very little power is needed to operate the horn, but much more is needed to make the motors work.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will oxidize and solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. When you turn on the power chair, nothing happens. The charger will indicate the batteries are full, but instead of being full of power, they are full of crud. Your warranty will most likely not cover replacement as this is due to customer neglect, but your insurance may still cover the replacement batteries if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own, type U1, 24v 33 amp, approx. $125 each at Batteries Plus or Interstate Battery. Good luck!
Dec 19, 2010 | Pride Mobility Products Pride Mobility...
Wont go forwards or backwards
are you sure its in gear. the nob on the moter should be towards the front of the machine! Hope this helps
Mar 12, 2009 | Pride Mobility Victory 3 Wheel Electric...
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Feb 07, 2009 | Pride New Mobility Victory XL 4 Wheel...
Health & Beauty Logo
105 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
