Question about Bissell Vacuums
I just replaced the belt on my bissell powerforce helix turbo and now I cant get the vacuum to move forward only backward
It seems like the bottom plastic piece is not on tight enough but I cant get the screws in any deeper
    Top Expert:
  • Bissell Master
  • 41,738 Answers
The plastic piece on the bottom may not have been properly seated before installing the screws.
Posted on Apr 20, 2014
SOURCE: Bissell powerforce
I just got done fixing a unit with this problem. After a bit of time, dirt will build up in the lower unit and clog the vacumm tube. Symptoms: No air flow coming out of the vacuum. Motor is hot. Stuff is spitting out of the front Motor wouldnt start it had over heated. You should remover the roller and clear the clog by hand. Let the motor cool down and it should start once it had cooled down.
Posted on Aug 19, 2007
reddevil6
  • 1673 Answers
SOURCE: belt on this vacuum
Take off the bottom plate covering the brush roll, take out the brush roll, check it to make sure the ends turn freely, the belt goes around the end of the brush roll, then stretch it to go over the motor shaft.
Posted on Mar 22, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt motor pulley on a bissell powerforce bagless vacuum
Yes, the motor shaft is also the pulley.
Posted on Jun 29, 2008
  • 16 Answers
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Posted on Nov 03, 2009
  • 231 Answers
SOURCE: Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Posted on Jan 07, 2010
Why does my belt Fall off my bissell PowerForce Helix
Your belt may be stretched out. Try installing a new belt.
May 06, 2016 | Bissell Vacuums
How do I clean the filter
The foam filter can be hand washed, squeezed and them dried.
The pleated filter really never seems to loose it stall smell after cleaning. It's best to tap it against the hard ground to free the dirt.
Washing it can cause odors.
Sep 27, 2014 | Bissell 2 Sets Bagless Upright Vacuum...
Cant find reset button
Hey Troy, the PowerForce Turbo Helix doesn't have a reset button. You may want to have a Qualified Technician at at BISSELL Authorized Service Center inspect your vacuum.
Here's a quick link to assist you in locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 28, 2013 | Bissell PowerForce Turbo Helix Bagless...
Turbo brush on bissell cleanview helix stopped spinning
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 07, 2012 | Bissell Cleanview Helix Deluxe Bagless...
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
Jan 10, 2011 | Bissell CleanView Helix 22C1 Bagged...
I have a Bissell Turbo - Powerforce Model #6585C - I want to know
First go here:
http://www.bissell.com/searchresults.aspx?searchtext=9500&mode=userguides
This is the PDF of the user guide. Start on page 18 and 19 and this shows how to change the belts.
May 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell powerforce bagless extremely loud.
It could be that the belt is worn. You can get replacement belts and the manual here:
Bissell PowerFrorce Belts and Manual
Nov 21, 2009 | Bissell 6594 PowerForce Bagless Upright...
Nov 03, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
