Question about Kwikset 94002-444 Polished Brass Tylo Entry Knob Brass
Stripped long screw
Where can I buy these screws separate for buying whole door knob
    Top Expert:
  • 42,970 Answers
You may be able to standard hardware as a substitute, provided the threads are compatible.
Posted on Apr 20, 2014
2 Suggested Answers
  • 5 Answers
SOURCE: I have extreme difficulty locking the deadbolt
Doors often sag downward just from use and gravity. This causes a misalignment of the bolt and the keeper (hole the deadbolt goes into) causing binding and dragging whenever you lock or unlock. You are correct that leaving this unfixed will quickly damage the lockset and be much more expensive to fix. A solution to the immediate problem is to lower the keeper to match where the deadbolt lines up. If you are semi-handy with tools you can probably do this yourself.
Extend the deadbolt with the door open. Push it against the door casing and mark above and below it with pencil. You should be able to "eyeball" it and see the problem by lining up the marks with the keeper. Unscrew the metal keeper from the jamb. Transfer the marks as close as possible from the casing to the jamb (surface where the keeper was). You will need to fill the old screw holes with wood because, when you remount the keeper, the new holes will be close to the old ones. You can use a sharpened popsicle stick, matchstick, toothpicks - whatever - to do this. Best to use glue. Tap them in fairly tight then break or cut the sticks level with the surface. Reposition your keeper vertically to match your pencil marks and screw it back to the jamb. Hold it in place in the new position and mark the screw holes then make a pilot hole for the screws with a nail. [Be careful not to change its position horizontally or the door won't close right] You may also have to remove some wood from the bottom of the hole behind the keeper where the deadbolt rests when locked. Easiest with a hammer and chisel but can be done with a good knife or drill and determination. I haven't looked but I wouldn't be surprised to find a Utube video of this process if you care to search. Good Luck!
Posted on Sep 23, 2010
How do I remove the doorknob to possibly oil it?
it would depend on the door knob construction and what was stiff inside it.
The problem could be part of the handle or part of the lock mechanism.
For a typical indoor door lever handle, undo the screws on the face plate and take the handle off and oil as appropriate. You may have oil handles on both sides of the door.
For a rotating door knob handle there is generally a single screw on the underside of the knob
For a lock mechanism, you could just spray oil inside the mortise moving part (you wouldn't have to dismantle anything to do this!).
However to dismantle it, you'll need to remove handles on both sides of the door, remove the square bar that slots between both handles and remove the lock mechanism (you may have to remove locating screws that exist on the mortise face. If lock mechanism is user serviceable then there will be screws to undo to allow it to be dismantled. If none exist then it is probably worth buying a new one.
Oct 16, 2014 | Hardware & Accessories
Remove stuck screw
If the screw head is stripped you will have to replace the knob and screw. Try holding the screw head and turn the handle is its a single knob. Otherwise use a hacksaw or dremel tool and cut about 3/8" away from the door surface, once you cut through you can use a small punch to push the screw through the door then pliers to pull it out. Alternately you could use a dremel tool and carefully grind the head of the screw down until you can brake the head off and pull the handle and screw out through the front.
Jun 19, 2014 | Top Knobs Hardware & Accessories
The thread on the screw has gone
Jun 19, 2014 | Amerock 3 Ring Knobs - BP1586
Stripped screws attaching dishwasher door
Go to the hardware store and buy the next larger sized screws.
Jan 03, 2014 | Kenmore Dishwashers
My wrought iron door has a tamper proof screw missing. Can I replace it with another type of screw like a flathead or phillips head?
You can replace it with any type screw head. I would recommend however using a screw with the proper shank size. That is to say, a srew that is the same diameter.
Oct 07, 2012 | Smedbo Door Knob in Wrought Iron
The center (Function) knob has stripped. Where do I get a replacement?
I would just take the old knob to Home Depot or another hardware store and buy a knob with a set screw.
Mar 20, 2011 | Euro-Pro EuroPro 6Slice Toaster Oven with...
The screws that hold our doorknob don't hold the knob anymore.They have loose threads and the screws are already too short that they don't hold the knob anymore. Everytime we turn the knob and pull it to...
Get a tap and re-tap the threads to the next screw size up. Then get matching setscrews. You could put a bit of Loctite on the new screws to keep them secure. Use a FINE thread tap so you get more threads in the knob.
Another solution is to clean and fill old screw hole with metal filled epoxy. Let is dry and re-drill and re-tap to original thread. Devcon makes a filled epoxy as well as JB Weld.
Mar 18, 2011 | Garden
Door Handle - Screw coming out
Not quite sure about your problem but, if it is a wood screw going into your door, you can take the screw out a insert a hardwood toothpick into the screw hole and reinstall the screw. this will fill any stripped out of the hole and screw should fit securely. If it is a metal to metal problem you can go to the hardware store or even walmart and buy a product called " Locktight". it is a liquid that you put on the screw and reinstall it. it will dry and lock the screw in place. Buy the blue if you want to eventually take it out at some point or buy the red, if you want it to stay in place and take a lot of effort to get it back out.
Nov 05, 2017 | Maytag MFI2568AES Stainless Steel Bottom...
I have old glass door knobs and the shafts are stripped and also need the set screws. Where can I find this parts?
Probably all you need are the set screws to lock them in place. They are sometimes allen head set screws, though some older ones will have a flat head screw like those shown here. In either case, a good hardware store with many drawers of small specialty screws should be able to set you up with what you need. Take a knob or two with you and make sure to get a screw with the correct size diameter and thread pitch, so you don't strip out the threads in the knob. (You can check the knob using longer screws to determine the correct dimensions, then find a set screw that matches.)
You could also try a specialty catalog along the lines of Van ****'s restorers, click here, or a specialty hardware supplier online like the one here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 08, 2009 | Hardware & Accessories
Door knob
A couple of ideas: Sometimes the top of the knob is a cap which can be levered off with a sharp blade. Or, there is a grub screw (which may need a hex key to turn it) in a hole on the underside of the knob.
Sep 21, 2007 | Computers & Internet
Kwikset 94002-444 Polished Brass Tylo Entry Knob Brass Logo
48 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
