Question about Apple eMac G4 Desktop
Forgot user password
I forgot user password what can I do I can afford to lose very important files on this computer
    Sergeant:
  • 264 Answers
Hi I'm Peter , You can change your user password by going in with your administrator password. Here are a few helps https://iforgot.apple.com/password/verify/appleid and see
http://support.apple.com/kb/HT1274 and
and Kappys answer
https://discussions.apple.com/thread/4251616?start=0&tstart=0
In OS X Lion or later, you can reset your user password with your Apple ID.
In Mac OS X v10.6.8 or earlier, follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
    forgot user password - http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1274/HT1274_Leopard.png
  6. Hope this helps.
Posted on Apr 20, 2014
What if computer will not take password to your account
If you forgot your BIOS password. see this... http://www.wikihow.com/Break-a-BIOS-Password
If you forgot your windows Account Login password, the following page is a good description of your choices... http://pcsupport.about.com/od/tipstricks/tp/find-lost-windows-passwords.htm
Also, check out... http://ophcrack.sourceforge.net/
If the above does not work, and you have important files that you don't want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. At least you may not lose you files.
Good luck
G
Jun 23, 2014 | eMachines T5048 PC Desktop
Tip
4 Common Windows Password Mistakes You Should Avoid
As the first safeguard of our computer data, a Windows password security is worthy of a user's attention. But in reality, few users are aware of the significance of a Windows password. Many users set a Windows password that can be easily hacked, like "123456" or "password", for convenience. Some users even forgot Windows password frequently without a password reset disk at hand. The following lists 4 common Windows password mistakes users easily make.
Mistake 1: Set A Weak Windows Password Like "123456"
When creating a Windows password, you should avoid the passwords like"123456", "password", "abc123", etc, which are too common and weak to be easily recognized, though it seems to difficult for you to reset Windows password . According to an analysis survey, the most popular passwords among nearly 400,000 exposed by the Gawker hack were "123456", with more than 3,000 people had it as a password. If you owned a Windows password like that, stop using them now. Meanwhile, it is better not use only letters or numbers which means great significance to you, like your birthday or names.
There are 2 key factors for a strong Windows password: length and complexity. An ideal password is regarded to be at least 8 characters long and composed of letters, punctuation, symbols, and numbers; avoid personal information, repetition, sequences, and dictionary words. But don't make it too complicated for your memory. Otherwise it happens to forget Windows password easily. A strong Windows password should be easy for you to remember but hard to hack.
Mistake 2: Always Use Same Windows Password
According to PC World, 75 percents of people had the same password for their email accounts and social networking sites. Have you also employ the password with other accounts for avoiding to lost Windows password?
Today we live in a password-drive world which make us have to remember credit card passwords, bank accounts, etc. Of course, it is an effective way to use the same password for getting out of the trouble with many different passwords. But the problem is that if it's compromised and someone finds it, the rest of your identity is at risk. So it is better not to use the same password for all your accounts, at least for your Windows accounts and other important accounts.
Mistake 3: Seldom Change Wind
ows Password
For many users, they may never remember to change Windows password unless they forgot Windows password. No matter how strong a password is, it may get hacked if the user doesn't change it all the time. Most computer experts and online security professionals recommend changing passwords and account login information at least once every three months. How long have you ever changed Windows password? Reset it frequantly and get into the habit of changing your password on regular basis.
Mistake 4: Forgot Windows password Without A Password Reset Disk
With the Windows password reset disk feature, it is no longer a big problem when you forgot Windows password. Computer experts strongly suggest that users create a password reset disk when setting a new password, which they will not lose access to your files and information. But many users in fact ignore the importance of the Windows password reset disk until they forgot or lost. If you haven't create a password reset disk, just start to create one now. You will find everything is still in order though password is gone.
This is the survey which we have collected from Security Community, more info about password management survey, go to its official site.
If you cannot afford to reinstall computer with your computer data lost after you forgot Windows password, an effective option is to use Windows password recovery tool like Windows Password Unlocker to reset your forgotten Windows password. it guarentee that no data will be lost after Windows password reset in 4 steps.
Step 1:
Download and install Windows Password Unlocker Professional in any available computer
Step 2: Burn a password reset disk with a CD/DVD or USB flash drive
Step 3: Set BIOS of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Reset forgotten Windows password
Now, have you mastered how to avoid the common Windows password troubles? Will you still get anxious when forgot Windows password or the password be hacked issues?
on Dec 30, 2010 | Computers & Internet
Boot password
Jun 22, 2014 | Fujitsu Siemens Celsius M460 Core2 Duo...
Samsung password
You should always tell us the Make & Model of the machine, and what Operating System it is running.
Jun 19, 2014 | Computers & Internet
Have apple eMac forgot user password can you help
You need to start up from the system cd for the eMac then use 'Password Utility' to change the password.
Alternatively, if you are transferring the files to another Mac, you can start up the eMac in 'Target Disk' mode by holding down the 'T' key during start-up until a Firewire symbol appears on the screen. The computer can then be connected to another Mac which will see the eMac as an external HD.
Apr 20, 2014 | Apple eMac Desktop
Forgot user password and cat log in.... i have a bunch of information on my computer and cant afford to lose it due to i never backed it up
If the computer have another account which have administrator privilege, you can use the account to help resetting your password.
But if not, you can refer to the article below to reset the password
http://www.appgeeker.com/guide/reset-windows-7-password.html
After that, you'd better to create a password reset disk to avoid a problem like this in the future.
Jan 08, 2014 | Toshiba Satellite Computers & Internet
Forgot Windows 7 Password?
Check these WEB sites for info to reset your password -
http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html
http://4sysops.com/archives/three-ways-to-reset-a-windows-vista-admin-password/
Jan 21, 2012 | Computers & Internet
I forgot the password to my user account in Windows Vista. How can I retrieve it or what can I do?
You won't be able to retrieve your password if your system is running vista. The only thing that you can do is to uninstall and reinstall windows. And of course you will lose your files that is why it is very important that you backup the files.
May 18, 2010 | Computers & Internet
Apple eMac G4 Desktop Logo
161 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
