Question about Hunter Dryers
Fan works for short time then stops
When switched on, the fan will work for about half a minute, the stops. After 5-10 minutes the fan will start and run again.
    Genius:
  • Hunter Master
  • 1,617 Answers
If you have a remote change the frequency settings & see if that does it.
Posted on Apr 20, 2014
5 Suggested Answers
ronaldo_ross
  • 1056 Answers
SOURCE: remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Posted on Jun 29, 2009
SOURCE: Whole house Fan Stops running after 10 minutes
Tightened the belt, lubed the fan and it seemed to work intermitantly.... Still ahving ussues..
aaaarg!
Posted on Jul 02, 2009
  • 3 Answers
SOURCE: Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Posted on Jul 27, 2010
al_kupchella
  • 843 Answers
SOURCE: My 32" Hampton Bay Minute
Sounds like an excellent idea. In case you don't get a certain reply, i suggest that you remove a blade from your old fan and take it with you to a store that has one on display. Check the spacing of the holes, and the number of blades. You might also find that the width of the blades and their pitch (which is determined by the bracket the blades are attached to) work out in combination to give you about the same performance. But if the bigger fan has a much flatter pitch, you might find it won't deliver as much air as your old fan did with the old blades. Good luck, Al K
Posted on Jul 26, 2011
Ac works fine when fan is on low but fan cuts off after a couple of minutes on high
Bad fan motor. Multi-speed motors have a set of windings for each speed. Your high speed is bad so the only solution is to replace the complete motor. When motors are going bad they will over heat and kick out on the heat safety. As it cools back down it will start again for a short time again until it gets hot again.
Jul 12, 2015 | Coleman Dometic Duotherm Rv Air...
My dryer starts to work for about 5 minutes and then stops when i try to restart it ,it makes a buzzing sound and wont start
Sorry I am no expert here but it have you checked your filter? It may just need cleaned.
Alternatively it could be an issue with the fan. Over heating could be causing the unit to switch itself off if the fan is blocked or damaged.
Good luck
Nov 13, 2013 | Dryers
Put a new fully charged battery in - the camera would lasted for a couple of minutes and then would not switch on. The battery works fine in an identical camera. Put in a second battery - that worked for a...
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 26, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Aug 19, 2009 | ViewSonic PJ506D DLP Projector
Cavelier 2000 - A/C Fan works for 1 minute than quits
Then i would suspect it's your switch that is the problem.
May 09, 2009 | 1998 Chevrolet Cavalier
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Compressor stops suddenly....and then starts again
most condenser units have a fan capacitor and a compressor capacitor and some combine it into one,take your cover off and look to see what you have,i'am thinking it the all in one and it should be replaced,let me know-mike
Jul 03, 2008 | Ruud UAKA042 Air Conditioner
1988 Audi 90 electric windows stop working
Perhaps it is a problem for an auto electrician. 30 minutes is enough time for a built up charge to dissipate, The charge/short circuit it is causing is not enough to blow the fuse however, since it works after letting the charge clear.
There is no response at all? it doesn't go half way up then stop etc?
May 25, 2008 | 1988 Audi 90
Dryers Logo
76 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
