Question about iHome Audio Players & Recorders
Ihome i11 led light flickers
Led flickers and is very dim, dimmer switch has little effect
  • 417 Answers
SOURCE: leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Posted on Nov 03, 2008
  • 10865 Answers
SOURCE: need to replace the HPM dimmer switch with a normal switch
This is not a difficult job. First of all go out to a home depot or other hardware store and purchase one three way switch. They come in white, cream, and brown.
Back home, kill the power to the lights you are working on. Then open up the dimmer switch, the other switch doesnt need to be changed. Now, simply draw a diagram of where each wire color is now connected and remove the old dimmer. Reconnect the wires. Remember that the white wire goes on the dull color screw and the other two go on the brass screws. Turn the power back on.
If you do all this and the switch only works correctly part of the time just reverse the two wires on the bright brass screws. Please mark this answer as a fixya!
Posted on Mar 09, 2009
  • 112 Answers
SOURCE: touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
Posted on Aug 21, 2009
  • 202 Answers
SOURCE: 3 way switch and dimmer. Switch and dimmer both
only incandescent light dim, fluorescent lights don't dim. What kind of light are you using
Posted on Mar 21, 2010
al_kupchella
  • 843 Answers
Please describe the old light fixture and the new light fixture. If the new light fixture is fluorescent, then using a dimmer with it won't work and is a fire hazard - unless you have a specially designed ballast which is designed to be used with a standard dimmer. If that is what you have, then the ballast in your new fixture is bad.
Posted on May 10, 2010
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Dose
Jul 14, 2015 | 2008 GMC Sierra 1500
Two black wires come to original switch. I have wired the dimmer turning the wires around and the switch will not work. What did I do wrong?
If the picture is accurate, I have had the same misfortune with this model. Two wires the same color means its not pole sensitive and can be wired either way. Replace it with a more expensive switch and you should be OK.
Nov 30, 2011 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
When I turn the light on it doesn't dim at all, and when the dimmer is at full power it flickers non stop. What is the solution?
Switch the hot wire and the wire going to the light around... you are wired basackwards...
heatman101
Apr 29, 2011 | Leviton Decora Light Dimmer Switch
Installed Acenti by Leviton single pole switch and when in "off" position, there is a flickering of light on and off, its like a pulse... model AC201-1LW... the only thing i can think thats wrong...
No you are getting a backfeed from somewhere else...either the neutral is no connected properly or you have a bad ground...
It has nothing to do with the amp. rating of the switch..
heatman101
Apr 23, 2011 | Leviton Acenti AC201-1LW 20 Amp, 120VAC,...
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
