Question about BayTec 13 gal.Square Ez Stor Bucket Pail and lid, Recessed handle and Lid
Can I get it in black?
I am looking for this design but I would like the bucket and lid to be black. Do you sell them in black? Thank you
Where is the location of fuel pamp electric fuses
If Its under the hood
  • Raise the hood of your car and look near the battery for a black, plastic box. Unsnap the lid and raise the cover. On the inside of the lid there should be a schematic of the fuse orientation, and inside this box there should be an array of circuit breakers, fuses and relays arranged according to the schematic. One of the small, black relays is likely to control the fuel pump. Near the relay there is also typically a red, 10-amp fuse labeled "FUEL," "F/P" or "FUEL PUMP." If not, check under the dashboard.
If its under the Dashboard
  • Use a flashlight to look under the dashboard. In most cases, there should be a lower cover to access the fuse panel. Remove the cover with a small screwdriver and pull the lid off of the fuse panel. On the inside of the lid there should be a label that identifies the fuse arrangement, similar to the label on the power center under the hood. Look for the same lettering that designates the fuel pump fuse. If the fuse is not there, look in the specialty fuse panels.
Jun 11, 2014 | 1998 Lexus LX470
I can't get the lid off my 11kg bucket of HTH. It's stuck.
I assume you've tried using a pry bar? If so and that didn't work, then the lid is apparently *frozen* to the bucket. Turn the bucket upside down. spray WD-40 or equivalent solvent around the perimeter of the lid and let it soak until the lid can be removed.
Jun 05, 2014 | Dehumidifiers
I need valve clearance specs for a 1998 saab 2.3lt 9-5 and lifter design, bucket in head???? Thank you!!!
I looked on all data. It says they are hydraulic and need no adjustment. Then again I could not find the model 9-5. Hth. Jmax611
Jan 30, 2013 | Cars & Trucks
A shopkeeper bought 20 buckets for Rs 1200. Find the selling price of each bucket, if he wants to make a profit of Rs 15.50 on each bucket.
Ow this is a math problem! Here is my solution:
Based on the purchased price or Rs1200 for the 20 buckets, each bucket would then cost 1200 / 20 = Rs 60.
To make a profit of Rs 15.50 per bucket, he should sell each bucket with the price of Rs 60 + 15.50 = Rs 75.5.
Mar 02, 2011 | Cell Phones
I am looking for a replacement lid for Rival slow cooker SCE502
I believe the design of the handle on the SCE502 is poor and will fail over time. The nut in ours fell out of the handle, and we were holding the black plastic handle while the glass lid was falling to the floor. Ours failed this weekend, and luckily, when the lid fell, it did not break. After looking over the lid and the black handle, I purchased a 1/4-28 screw and a 1/4-28 nut (original was corroded). I drilled a hole completely through the handle and now the black handle is securely attached to the glass lid with a stainless steel screw and nut..
Aug 23, 2010 | Rival 3755 5.5-Quart
It wont **** up the water anymore. why not?
try this it might help on the lid of the water bucket you will find a red filter if this is dirty give it a wash and see if that helps, also make sure the black seal is in place on the top of the window where the water bucket overlaps, also if the clearview window is damaged where the unit rests on the carpet this can be a prob
Oct 23, 2009 | Bissell 1699 ProHeat Clear View Upright...
My bucket has a hole in it and I need to replace it. I don't know where to look for a bucket. It's an older model: 58052650100.
I know this isn't the answer that you are looking for, but auto parts stores usually sell a patch kit that's intendend for Washer Fluid Reservoirs.
If it were me, I'd patch it.
Aug 20, 2009 | Kenmore Dehumidifiers
Everstar MPM 08CR BB4 P1 light is on and unit wont start. I emptied the bucket, I drained the hose inside bucket area and put back where it wouldnt be in the way of the bucket, I unplugged and plugged back...
"The black plate with floater in the bucket" is what signals that the bucket is full of water. So if it isn't in the right place then you will get "P1" (Problem 1 which means bucket is full). The "black plate" needs to flop down inside the bucket for it to register as empty. When the bucket fills the floater makes the plate go to the top and it shuts off the unit.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
No suction to retrieve water from carpet
The tank lid of your recovery tank is designed to engage two tabs to lock the front of the lid down on the seals. Look at the front corners of your recovery tank. You will see a tab extending out on each corner. These two tabs insert into the corresponding grooves in the lid. Once engaged, the lid folds down and the clip on the lid snaps into the back of the tank. When installed correctly, if you pull up on the front of the lid, it should NOT lift away from the tank. The front of the tank has a square "duct" that is removable for when the hose is inserted for furniture, etc. Make sure that this duct is replaced back into the tank when using on the carpet.
Jan 19, 2008 | Vacuums
BayTec 13 gal.Square Ez Stor Bucket Pail and lid, Recessed handle and Lid Logo
100 people viewed this question
Top BayTec Home Experts
Donni Steen
Tom Chichester
Are you a BayTec Home Expert? Answer questions, earn points and help others
