Question about MTX Car Audio & Video
I have a mtx thunder 7801 series amplifier well i got a stereo from someone and i didnt know it a the time but it had the wrong plug in the back of it so when i hooked my amp up to it what i thought was the remote wire wasnt and as soon as i hit the power button on the stereo if fried the fetts from the circuit board to the heatsink can this be fixed
    Scholar:
    New Friend:
  • 82 Answers
The short answer is probably yes... easily, probably no. If you are lucky and only have one or two shorted transistors, then you can cut the leads on those and see if it powers up without blowing a fuse. Also check for shorted diodes and burnt resistors. If all FETs (or most of) the FETs mounted to the heat sink are shorted then it is probably not worth taking the chance putting the time and money into fixing it, just to have it smoke again. Also they are likely in parallel so it is a little more difficult to determine the bad one as they may not all be bad. Measure with an ohmmeter and find the one with the lowest resistance and remove that first and keep going until you believe you have gotten them all. Normally repairs like this are not for someone with little or no experience on amp repair, but if you feel like taking it on, good luck!
Posted on Apr 20, 2014
4 Suggested Answers
  • 113 Answers
SOURCE: my 7801 doesnt turn on
check pwm circuit amps turn on with 3-4 volts on mosfet gates ic 494, 5252or 555 controll these.hit me up for more
Posted on Aug 09, 2007
  • 31 Answers
SOURCE: i need help hooking this up
"is the got two wires in the ground and remote turn on wie"
Can you be more specific about the wiring...where the two wires are connected to and where they come from, and I'll try to help you.
Posted on Mar 30, 2008
kcarmax
  • 30 Answers
SOURCE: i have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Posted on Mar 01, 2010
Why does my MTX thunder 702x amplifier cut on and off
Check fuse on amp under hood. Also, check wire connections makes none of them are loose and move your RCA jacks around to see if you have a short.
Jan 04, 2012 | MTX X Thunder 702X Car Audio Amplifier
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
I have a mtx thunder 7801 and a sledge hammer box
Feb 28, 2010 | MTX Car Audio & Video
Why do my mtx 8100d amp keep cuting off
wrong wiring for the speakers. to low of an ohm load so amp is going into protect mode. rewire to 4 ohm stereo.
Jan 18, 2010 | MTX Thunder 895 Car Audio Amplifier
Need help MTX 1501d amp diagram
Remove cover and set in direct sunny window for long time, may be no problem with it, Took a month to dry one of my amps out enough that it decided it would come back to life, cell phone dropped in sink took 2 weeks, If you try power to it too soon --fried--, good luck finding diagram and repairing it sincerely-hope its okay, good amp, bad luck,
Mar 13, 2009 | MTX Thunder 1501D Car Audio Amplifier
Amp works fine i think??? but Prsim efx not working at all
You need to contact MTX tech support before the warranty runs out. You'll probably have to get an RA number to send it back.
http://www.mtx.com/caraudio/contactMTX.cfm
Oct 18, 2007 | MTX TA4501 Thunder 4501 MonoBlock Car...
My amp doesn't turn on...
If there is a zero ohm connection across the B+ and ground terminals, it should blow the fuse as soon as you apply power.
Oct 10, 2007 | MTX Thunder TA7801 Car Audio Amplifier
My 7801 doesnt turn on
Apr 03, 2007 | MTX THUNDER7801 SUPER AMPLIFIER CLASS D...
Car Audio & Video Logo
44 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
