Question about ASUS R503u-rh21
Checking disk for error message - ASUS R503u-rh21
    Top Expert:
  • ASUS Master
  • 24,419 Answers
Are you running chkdsk/f ?
Posted on Apr 20, 2014
Sounds like your computer is running the built in "chkdsk" program which checks your hard drive for errors. This program can sometimes take over an hour. I would plug the laptop into power and let it run its course. If it takes longer than an hour or two, you may have a failing hard drive.
Apr 20, 2014 | ASUS R503u-rh21
Error message stop 0x00000024
which operating system ?
If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
Feb 24, 2013 | Computers & Internet
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
I have an emachine em250 and I am recieving an error message saying (check cable connection...!) pxe-e63 error while initializing the nic pxe-mof: exiting intel pxe rom no bootable device--insert boot disk...
This error message is generated when the processor can't detect the presence of a hard disk because either the disk is dead and it will have to be replaced or the southbridge chip on the motherboard (the one that controls the disks) has failed - both severe hardware defects.
If after replacing the hard disk you get the same message then you need a new motherboard.
May 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hello my acer laptop is giving a message disk error hit alt ctr del for start up i do that but the screen stays black with a with small white blink - in the left hand upper corner
How to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
courtesy of Microsoft.com
Oct 14, 2010 | Acer Aspire 5315 Notebook
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Error message
Please check if you have any floppy Disk in you A:\ Drive
If there is not Floppy, Try to change the first boot driver as you HDD in the BIOS
Please revert for further assistance
Thank you for choosing Fixya
Oct 20, 2009 | Compaq Armada E500 Notebook
My dell 8400 displayed this error message 00f0: 136c and 00f0: 0242 What can I do. Thanks
This message is likely to be due to a segment error on your hard drive.
Checking /correcting disk errors
You can use the Error-checking tool to check for file system errors and bad sectors on your hard disk Open My Computer and then select the local disk you want to check.
  1. On the File menu, click Properties.
  2. On the Tools tab, under Error-checking, click Check Now.
  3. Under Check disk options, select the Scan for and attempt recovery of bad sectors check box.
To open My Computer, click Start, and then click My Computer.
  • All files must be closed for this process to run. If the volume (drive) is currently in use, a message box will appear prompting you to indicate whether or not you want to reschedule the disk checking for the next time you restart your system. Then, the next time you restart your system, disk checking will run. Your volume will not be available to perform other tasks while this process is running.
  • If your volume is formatted as NTFS Windows automatically logs all file transactions, replaces bad clusters, and stores copies of key information for all files on the NTFS volume.
Mar 31, 2009 | Microsoft Windows XP Home Edition
ASUS R503u-rh21 Logo
47 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
