Question about Crock Pots & Slow Cookers
3 lights blinking on my sccpvc709-s
Unable to program timer or low vs high
  • 3,247 Answers
Someone suggested there is moisture under the pot. Use hair dryer to dry it up.
Other suggestion is if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state
The instruction manual does not say anything. But you can find the Crock Pot number to call.
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-crock-pot-Site/Sites-crock-pot-Library/default/v1397907098387/documents/instruction-manuals/SCCPVC709-S_43_38491059.PDF
Posted on Apr 20, 2014
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
My rival crock pot model 5865 sticker on the heating unit that tells you high/low etc. fell off and now I don't know which position is high or low? Can you help? Can I buy a replacement sticker? H
L to R Round Left Button- Low-High - Warm Two buttons over each other Top - time up, Bottom, Time down Most Right Button - OFF Lights Left - HIGH Center - KEEP WARM Right - LOW
Nov 09, 2012 | Rival 5865-W 6.5-Quart Slow Cooker
On the dial there is off, low, high and auto. What does the auto do? If I select auto is there a timer on it that shuts the pot down after a time? Is fo what is the time.
There is no timer -- with the dial set to auto, a thermostat opens and closes turning the heating element(s) on and off to keep the pot at a fairly constant temperature. The high setting can continually boil the contents, and can burn the food if not stirred. The low setting is for keeping contents warm.
I'd use "auto", if the pot is not going to be monitored.
Charlie
Mar 27, 2011 | West Bend Crock Pots & Slow Cookers
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
I need an owners manual for the SCVC651
I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
"Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
Hopefully, this helps answer your questions!
Nov 23, 2010 | Rival SCVC651-F Slow Cooker
Is there a timer I can purchase for the SC60?
A timer would probably work for a slow cooker with only a switch for low, medium or high on the front of the cooker, but this slow cooker requires that after you plug it into the wall you have to tell it how you want it to cook, it won't start cooking automatically. In other words, you have to press buttons to make it cook. Hope that's clear, I know sometimes I'm not.
Apr 10, 2010 | CorningWare SC60 Slow Cooker
Need directions for presidents choice slow cooker
Heat intensity is warm, 1, 2, 3 (highest)
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
Apr 11, 2009 | Crock Pots & Slow Cookers
Green light is blinking, but I am unable to trun the power on.
rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
Oct 30, 2007 | Rival 38601 Smart Pot 6-Quart
All Three Lights Blinking
We have their 6 quart Crock Pot. Same problem cited here!
We have found that, if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state. It has worked for us on several occasions so we trust it and have found no "adverse results"!
Hope this is a help to others.......
Jan 28, 2007 | Rival 38651-C 6-Quart
Crock Pots & Slow Cookers Logo
439 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
