Question about Simplicity 42 Toro Timecutter 20hp Kohler Zero Turn Lawn Mower 2012 Ss4235
Timecutter 42 kholer electrical problem
Battery not charging
    Top Expert:
  • Simplicity Master
  • 39,347 Answers
The battery may not be chargeable and will have to be replaced.
Posted on Apr 20, 2014
I have a toro timecutter ss5000 and the battery will not stay charged. I bought a new battery same problem. What actually charges the battery the solenoid?
Actually is the alternator on the engine thru a voltage regulator and 25A fuse then thru the ignition switch to the starter solenoid and on to the battery..
Mar 23, 2015 | Toro Garden
How do I replace an idler pulley on mower deck on toro timecutter mx 5060?
Release belt tension, unbolt the pulley, replace it with a new idler pulley. If you need more help, please follow up here.
Jul 29, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
Can you jump start a toro zero turm mower with a car battery and jumper cables?
Better to not jump them can burn the leads up. Pull it out and slow charge it
Jul 17, 2014 | Toro NEW 42 TIMECUTTER 21.5 HP KAWASAKI...
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
I have a sears lawn tractor with a Kholer courage 20 HP. Engine just clicks with the key is turned. Took the battery to have tested and was told the battery is good. But, the tractor will start if I jump...
No, it sounds to me like it is one of the safety switches is a bit corroded, along with a battery that may not be fully charged, you are not getting enough voltage to turn the engine over. What I would first do it disconnect the battery, take apart all connections of the cables, where it mounts to solenoid, where ground cable connects to the tractor, etc. Then put everything back on. Charge the battery, or jump the tractor to get it started and let it run a bit, which will charge the battery. You may need to check wire connections that go to various safety switches, too. Under the seat, where it connects to the transmission, etc. This does not sound like a big problem at all.
Mar 08, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
THE MOTOR RUNS BUT DOESN´T CHARGE THE BATTERY
Contact your local vendor.
The highest probability is replace the voltage regulator.
Have you added or modified anything electrical?
these regulators don't handle very much in the way of regulation and are really only designed to recharge the battery after starting.
Hope this tip helps.
R/
Davdi
Feb 12, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Battery wont stay charged
HAVE YOU CHECKED THE CHARGING SYSTEM? YOU COULD HAVE A BAD VOLTAGE REGULATOR. ITS REAL SIMPLE TO DO.START THE MOWER,PUT IT AT FULL THROTTLE.TURN A MULTI-METER TO VOLTS AND TOUCH THE BATTERY.YOU SHOULD READ 13.5-14.6 VOLTS.IF NOT GOOD CHANCE THE VOLTAGE REGULATOR IS NO GOOD.
Jul 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Simplicity 42 Toro Timecutter 20hp Kohler Zero Turn Lawn Mower 2012 Ss4235 Logo
136 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
ray gallant
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
