Question about Kenmore Washing Machines
I have a Kenmore 700 series clothes washer. It doesn't fill with water. The water just keeps on running through. It eventually just gives up trying to fill and stops. Before this happened it would sometimes get stopped in it's cycle just before the first spin. Whenever that happened we would have to manually advance it then it would finish the load fine. But that might be unrelated to the first and more serious problem.
  • 4 more comments
  • jeremybrown Jun 19, 2009
    No the water isn't leaking. It's just running right through...I'm pretty sure. I'm not at home right now. I don't have the model # on me but I do have the serial # if that helps. It's: CT3741574.
    I can get the model # to you at around 5:30pm today if it will help.
    Ok here is my Model #:
    110. 27741600
  • jeremybrown Jun 20, 2009
    The drain hose seems to be fine. It's in it's usual position, going into the drain thing on the wall.
  • jeremybrown Jun 27, 2009
    Thanks for your suggestions but the problem seems to have fixed itself for now. Not sure what happened but I tried to just run a test cycle without any clothes in it and it worked fine. not sure if the problem will come up again. Seems to be working fine now though.
    .....Oh except for the other problem that I mentioned: It sometimes stops at the beginning or end of the first spin cycle. Manually advancing it works to get it to finish. Do you have any ideas on what that could be?
  • jeremybrown Jul 03, 2009
    Sorry I didn't respond sooner.
    But no, pushing down on the lid near the switch didn't seem to do anything.
    Any other ideas?
    And thanks for getting back to me on this.
  • jeremybrown Jul 17, 2009
    I'll try to order that timer part today. Thanks. I'll let you know if it works.
    President:
  • 1,136 Answers
Hi, I can help you. While the washer is filling, does the water go out the drain hose?
Posted on Jun 20, 2009
  • 10 more comments
  • Victor
    Victor Jun 20, 2009
    It sounds to me like the drain hose might be lower then the water level in the washer tub. Check and see if the drain hose has dropped down at all.
    Vic
  • Victor
    Victor Jun 20, 2009
    Hi, Just want to know if I helped you at all. If I can assist more, please let me know.
    Vic
  • Victor
    Victor Jun 20, 2009
    When the washer is filling, does the water stay in the washer or does it release out the drain hose?
    Is the drain hose solid in the wall pipe or does it rest in the pipe with room for air to get in the pipe as well?
  • Victor
    Victor Jun 21, 2009
    The reason I am consentrating on the drain hose and how it is connected to the wall drain is, this sounds like it has created a direct syphon some how. After the washer has went through the drain cycle, air needs to be able to get into the drain hose to create an air gap. If air can not get intothe drain hose after the spin cycle, the next time the washer fills, it will continue to drain the water.
  • Victor
    Victor Jun 25, 2009
    Hi, I am curious if you still need assistance with this issue?
    Vic
  • Victor
    Victor Jun 26, 2009
    Hi, Can you let me know if this issues has been fixed please?
  • Victor
    Victor Jun 27, 2009
    When you notice the washer has stopped, push down on the lid above the lid switch area nad see if it starts. Sometimes the lid switch will be intermitent before it goes out completely. Because it happens around the spin cycle, I would check that first.
    Vic
  • Victor
    Victor Jul 02, 2009
    Hi, Did my suggestion on the kid switch help you at all?
    Please let me know either way so I can help more if needed.
    Thanks
    Vic
  • Victor
    Victor Jul 03, 2009
    The only other option would be to change the timer. I must have a bad spot in the timer motor. Is this issue getting more consistant?
  • Victor
    Victor Jul 03, 2009
    I am having problems with my gmail where I recieve notice of you return response. If I do not respond right away, it's because of my mail. If I don't respond with in 30 minutes, your question will go back to the main page for another expert to answer.
  • Victor
    Victor Jul 03, 2009
    Here is the timer part #280225 and the cost around $90.00.
    The next time this act up, try wiggling the timer knob instead of turning it and see if the washer start. Just another way to be sure the timer is the problem.
    Vic
  • Victor
    Victor Jul 17, 2009
    Ok Thanks for keeping updated.
    Vic
  • 297 Answers
Does the water leak and drop down? It would be helpful for assisting you if you give us the Model number of your machine.
Posted on Jun 19, 2009
  • sabharish
    sabharish Jun 19, 2009
    Alright..I will wait for you
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Jun 15, 2017 | Kenmore Washing Machines
Kenmore 700 series washer won't fill with cold water
Cold water supply valve on? Otherwise, you may have a problem with the washer electric solenoid fill valve.
Apr 12, 2015 | Kenmore Washing Machines
I have a Kenmore 700 series washer and it fills with water then stops. It's NOT my lid switch. I have tried to find someone with the same washer and same problem and can't find nothing. Can someone please...
If you are sure its not the lid switch, then next would be the water level switch. Once the machine fills, it should switch an internal set of contacts to make the washer run. Last and worst case scenario would be a dead motor.
Mar 24, 2015 | Kenmore Washing Machines
I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Jul 07, 2009 | Kenmore Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 700 Series - No drain/spin
WOW, THIS IS AN EASY FIX, YOUR LID CONTROL SWITCH IS BAD, YOU CAN EASILY BYPASS THIS OR REPLACE IT, I THINK THE PART IS AROUND $25
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 700 series top load washer problem
Take the washer back. We just bought the same one and have the same problem
Feb 18, 2008 | Washing Machines
Washing Machines Logo
138 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
