Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Scale problems, too big for paper size!
Ive got the paper size correct but the printer wont scale the image correctly when it prints--HELP!
    Genius:
  • 1,018 Answers
I'm not real familiar with Kodak printers but on the ones that I am familiar with, you set the scaling via the printer driver.
Can you please tell me exactly what you are trying to do and what you are getting.
Don
Posted on Jun 19, 2009
How do I get a Blow up (say 150%) PDF snapshot view of an image to print from A3 not A4 print tray
Hi Paul,
I would try and insert the PDF as an image to Powerpoint, crop the image to your desired proportions, scale it up to your preference, then print the Powerpoint slide on A3. Alternately, print the slide to PDF, then print.
Good luck
Feb 22, 2015 | Office Equipment & Supplies
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Can't get small envelopes to print correctly on hp laser jet pro MFP M127fw
Go to printer setting options and choose paper size and font size, according your size choose it. I share a more help full links.
Read More Help...
Scale document to fit on different paper sizes
Resize the page or paper
And HP Printer Support
Thanks,
Aug 27, 2014 | Office Equipment & Supplies
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Mar 31, 2011 | Office Equipment & Supplies
Faded printing on 5x7 size paper
Sure. One of the papers is probably clay based (Shiny) and one is rag based (rough and dull). Clay based produces the most vibrant inkjet images and rag based produces the best laser printer images. I bet the two papers are different in composition. I see this all the time.
Mar 29, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I change the print size on my D4160 hp printer
There basically two approaches to changing the print size of your printer whether D4160 printer or any modern other particularly hp printer.
1. Go to file/print or simply do ctrl P on your keyboard. The print menu pops up. Go to properties/features. When the features tab opens look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. The other procedure is to simply right click on the image and select print. A print wizard pops up. It enables you to chose size of images and automatically fits them into 1 per page, 2 per page or 4 per page depending on how many images you selected in the first place. However this is meant specifically for images/photos.
3. Again you may decide to physically resize them in the application (Word, CorelDraw etc) you are working with before sending print.
Sep 03, 2009 | HP Deskjet D4160 InkJet Photo Printer
The images are too big.
go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 19, 2009 | Dell Office Equipment & Supplies
C6180
load the paper in the tray
go to file menu then page setup.
select HP all-in-one printer
choose the paper size, orientation and scale percentage
chick ok then choose print from the file menu
configure the print settings suited for your project.
click print
make sure that you choose the correct paper type before you click print.
Nov 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
Can i print the image smaller?
  1. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
  2. In 'Page Size', select the paper size specified in the application. If you select a size that cannot be selected in your printer, a message will display informing you that the setting has been changed to 'Fit-to-page' printing. Select 'Scaled Printing' again.
  3. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape).
  4. In 'Printer Paper Size', select the paper size loaded in the printer. In 'Scaling', the magnification at which the document will print so as to fit exactly on the output paper size will appear as a reference value.
  5. In 'Scaling', specify the percentage. You can select from 20% to 400%.
  6. Click 'OK'.
Mar 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
79 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
