Question about ASUS Computers & Internet
Asus laptop plugged in but not charging
Power block green light on
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 94 Answers
Is the led light (green/yellow) on on the charger? If not, seems like charger is not working. Make sure all cables are connected fully.
Posted on Jun 04, 2014
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
  • 97 Answers
SOURCE: d600 laptop boot problem
The D600 is plagued with power up problems for 2 reasons. First the connector on the motherboard to the power button is very sloppy and after awile it breaks contact. If you put pressure under the docking port area and press the power button it may start. The second is the memory slots. I know you said you replaced the memory, but it is the slot that is a problem. Remove the memory and put 1 chip in "A", then press down on the chip while trying to boot the laptop. If this works then get a peice of foam or pad and place it on the chip. When you put the cover back on it will push down on the chip and should boot. Repeat this process for "B".
The green light does signify a charged battery! This is also a possible reason for not booting. Remove the battery and try to boot with only the power supply. A shorted battery will stop the laptop from starting up.
If all of this does not help then remove the battery and the CD Rom, then try to boot. Finaly if nothing helps you should buy a new Laptop or a used one on E Bay. You could get a used D600 on E Bay that has a good motherboard for cheap money and use your drives and LCD. I work on D600 and D800 all the time. Let me know how you make out!
Posted on Dec 09, 2009
  • 3278 Answers
SOURCE: I have a asus m6000 laptop the power supply green
Hello.
The most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
Hope this helps.
Posted on Dec 23, 2010
  • 6 Answers
SOURCE: sir i have acer 4720Z
Hello
It could be one of two things either the Power adapter is damaged or the connector wich is soldered to the motherboard has come lose. I suggest you try with another compatible power adapter if you can, to be sure but its most probably a faulty adapter.
Good Luck.
Jay
Posted on Feb 28, 2011
  • 184 Answers
SOURCE: The charger for my asus
Asus x5dc works on a 90watt ac adpater with 5.5mm*2.5mm dc connector. Try this link below:
http://www.chargerbuy.com/replacement-asus-ac-adapter-19v-4-74a-adp-90sb-bb.html
Posted on Mar 07, 2011
My Asus lap top will not turn on or charge. There are no charge lights. What can I do?
Look carefully at power plug port. If center pin wobble or loose then order that part for your motherboard and take to any electronics shop to have installed. If power plug port not broken. Then use multimeter to check output of your power block. If you don't have a multimeter, any electronics shop can check for you. If no output, then buy replacement power block. Its a fact, power blocks fail infinitely more frequently than power plug ports which only fail due to forced improperly aligned plugging. If center pin no longer centered, trying to force the plug in only guarantees damage. On laptops, that usually requires total disassembly to gain access to the circuit board, unsolder and remove the defective part and solder in a replacement, then reassemble.
Sep 20, 2015 | ASUS Computers & Internet
Why is the orange (battery) light on?
Your laptop is having power issues
could be the battery is dead
the charging system is broken
or the power cable is bad
May 31, 2015 | ASUS Computers & Internet
My ASUS t500ia will not turn on anymore. Even when plugged in. The charge light is green
Hold the power button down for 30 seconds or more. Sometimes with my asus laptop i have to do this 2 or 3 times to get it to power on.
Feb 23, 2015 | ASUS Transformer Book Flip TP500L-UB51T...
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
The battery led blinking red/green
Disconnect power cord. Please take out the battery. Hold down power button for a minute and then connect only power cord. Restart it again.
Jun 24, 2013 | ASUS Computers & Internet
Asus w7sg-3p003c notebook no power
Check if the power source is charging. That means, the plug that goes into the wall should have a brick like box in the middle of the cord between the plug and laptop. That has a light on it. If it takes a charge and stays charged, the light will be green and bright. If there is no light, this is your problem. If no light, the power supply is shot and you need to get a new one. You can get that from a batteries plus store or the manufacturer. If the power supply charges and holds a charge, has the green light, but the laptop still wont come on, you should seriously consider taking it to an independant laptop repair place. They are pretty good on prices, as long as they are independant and not a manufacturer or retail store. The reason for that is, if it is in the laptop, it is a nightmare to troubleshoot if you don't have experience as inside the machine it is so packed in and compressed, you may never get it back together again.
Sep 28, 2012 | ASUS W7SG-3P003C Notebook
ASUS Eee PC Seashell series notebook will power up for a second and then go out
Remove the main battery and try again, have the power supply charger checked to make sure it is working properly, if okay the DC jack in the laptop is a common source of trouble. The unit will need to be taken apart to assess the motherboard.
Jun 03, 2012 | ASUS Eee PC 1015PEMMU17RD 101 LED Netbook...
Plugged in not charging. Green light is on
sounds like the battery is bad if theres power up but turns of when unplugged then bad batt
sorry
Feb 15, 2011 | ASUS U52F-BBL9 Laptop
Asus ac adapter will not wrk green light on adapter
First check the wall socket make sure you are getting power, plug a lamp into it for instance. If there is no green light on the adapter then it is bad and you will need to order a new one from your computer manufactor.
rate with 4 diamonds
Mar 02, 2009 | ASUS AC Adapter- Universal Notebook AC...
Computers & Internet Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
