Question about Traeger Industries BBQ100 All-in-One Grill / Smoker
Traeger grill get to hot on smoke - Traeger Industries BBQ100 All-in-One Grill / Smoker
    Novelist:
    Scholar:
  • 197 Answers
If you're cooking when it's hot outside, it's hard to maintain low temperatures. In the heat of summer, I have to tend my grill continually opening and closing the lid to keep the temperature down to my cooking temp of 180. That, of course, lets the smoke escape. If it gets too hot when the temperatures are moderate, i.e. 60s and 70s, the augur may be dumping too many pellets into the fire pot and need realigning. I suggest you contact Traeger customer service at http://www.traegergrills.com and see what they suggest.
Posted on Dec 04, 2014
2 Suggested Answers
  • 34 Answers
SOURCE: I have an electric Traeger grill. I plug it in
Make sure your grill is unplugged. Them take the controler out and there is a fuse on the back side of the control. There is also a new fuse there to replace the old one. If the fuse is blown, you could have a bad hot rod or other component that is bad. Usually the hot rod is the problem and they should be under warrenty so call Treager and get a new one sent. If the fuse blows after it is replace, you can un hook the purple wire and replace the fuse and see if it will work them. If it does, it is the hotrod.
Posted on Apr 17, 2010
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Traeger grill not smoking
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
Jun 14, 2014 | Traeger Industries BBQ100 All-in-One Grill...
My traeger smokes but won't heat up...I have it on high...not smoke.
Have you cleaned the ash out of the firepot? I clean mine with a shop vac after every five or six uses because the ash builds up and "insulates" the fire, keeping air from the fan reaching it so it just smolders and never really gets hot.
Apr 01, 2014 | Traeger Industries Grilling
Not smoking
Traeger grills just will NOT smoke at temps much above 200 degrees. I have to stand by my grill continually in the summer to keep opening and closing the lid to let the heat out. That also lets the smoke out. I also have turned the grill off and on to try to maintain the temperature at 180 degrees where it smokes best and cooks low and slow. It's less of a problem in the winter months. Then I find myself setting the temperature higher turning it from low to medium and back to maintain the temperature I want.
Mar 30, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Won't light
Sounds like you need to replace the hot rod. Contact Traeger on their website at www.traegergrills.com for parts and instructions.
Jan 22, 2014 | Traeger Industries Grilling
Won't light
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
What is the desired smoke temp
For "Hot" smoke: between 93 - 107 C (200 - 225 F)
For "Cold" smoke: below 30 C (85 F)
Aug 06, 2012 | Traeger Industries BBQ070 All-in-One Grill...
Traeger 075 tripping GFI continually
May be too much moisture on the hot rod.
From Traeger:
Jun 19, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Traeger Industries BBQ100 All-in-One Grill / Smoker Logo
383 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
