Question about Remington F5790
The trimmer assembly has come off completely, in one piece.
The trimmer assembly on the side of this Remington F5790 has come off completely, in one piece. I would like to put it back on so it slides up and down normally. The rest of the shaver appears to work OK.
    New Friend:
    Problem Solver:
  • 7 Answers
If the rest of the shaver works OK, then there may be a small detent on the slides that is broken; this could be on the trimmer grooves or in the mating grooves on the shaver body. In either case, you may need a new part.
If none are broken, then you may be able to press it back in the same way it came out; light pressure, but do not force. If unsuccessful, you may have to pry off the back to reinstall. A flat (not sharp) object inserted in the groove that runs around the body should pop it free; pry carefully as you work around the case. If unable, your options are to find a service shop or replace.
Posted on Apr 22, 2014
4 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: remington microscreen3 tct problem
I can only comment genericaly for this:
Most likely the internal drive shaft is defective. In some models there is a gear box. This may not be coupling correcty due to a failure. In any of these cases it will most likely need replacement parts to be reliable again. Your shaver should never fall apart!
You can call the company and enquire about where to send the shaver for service. Some of these companies have a flat rate fee for service. Look for your reciept to see if it is possibly under warranty. If the estimate for repair is too high, then you should consider a new shaver.
I would suggest for you to try getting a higher end type model. From personal experience and the research that I have done in the past, I found the Philips and the Panasonic to probably be the best shavers around at this time. You may pay a little more, but they are worth the few exra dollars for the performance and reliablity.
Jerry G.
Posted on Aug 25, 2008
brector3
  • 1623 Answers
SOURCE: Re Remington electric shaver R5130, "User &
The outer combs must be turned first so that they can be removed. You will find instructions posted at shaveroutlet.com. See link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_36_1.jpg
Posted on Nov 14, 2010
  • 1739 Answers
SOURCE: my Remington f5790 shaver wont charge
You likey need to have the battery replaced. This needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Posted on Apr 05, 2011
How do you take apart a Remington F5790 razor?
To open the case you will need to pry off the front grip with a small flat screwdriver or similar object. This will reveal screws underneath. Remove the screws to take off the cover.
Mar 19, 2017 | Remington Health & Beauty
Back put together trimmer
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer, which includes how to reassemble it: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Dec 09, 2013 | Remington MB-300 Beard Trimmer
Want remington shaver manual f 5790
You can download the user manual for model F5790 at shaveroutlet.com. Use link below and then click on 'User Manaul' near the add to cart button
http://shaveroutlet.com/shavers/foil-shavers/remington-f5790-titanium-pivot-and-flex-triple-foil-shaver-p-819.html
Mar 17, 2013 | Remington Health & Beauty
Change Batteries in F5790
Batteries require soldering. Compatible battery type can be found at shaveroutlet.com
Shaver Replacement Battery AA NiMH
Oct 28, 2012 | Remington F5790
Remington F5790
Get a toothpick and clean around the where the head slips in. the build up does not let the head seat.
May 31, 2012 | Remington F5790
I have a F5790 and the head pops off when you turn it on. Is it trying to tell me it needs new blades or what?
Most likely, there is a build up preventing the foil from latching into place properly. See video at shaveroutlet.com to help correct this problem. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-sp-390-foil-and-cutter-set.html
Sep 15, 2011 | Remington F5790
The foil of my 5790 razor is damaged. How to I remove the damaged foil?
remington SP390 replacment blades and screen foil for remington f5790 heads replacement parts.
Aug 22, 2011 | Remington Health & Beauty
My Remington f5790 shaver wont charge
Feb 12, 2011 | Remington F5790
Remington F5790 Logo
158 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
