Question about Casio Parts Cash Register PC Desktop
Casio te 4000f use i just bought one and it gives me E194 select menu error what should i do
  • 2 more comments
  • selahattin ozguc
    selahattin ozguc Apr 20, 2014
    Thanks for the cooment, I tried what you said but as soon as i turn power on recipt is feed is working i know FFFFFFFFF should come before I press subtotal, I will try to explain what happens from first place. I just bought this till first thing i have done is put price and name on each department which i am going to use on my take away i didnt do VAT yet and when i turn key to reg mode to try departments is gives me error (E194 select menu) I know there is not such an error on the code list I have check dealer manual and user manual now I am stuck can you help what should i do.
  • selahattin ozguc
    i just manege to do recipt feed function FFFF came on and pressed subtotal reg mode after but still doing same error.
  • selahattin ozguc
    FC : 00040000010800
  • Electroboy
    Electroboy Apr 22, 2014
    That is a fairly normal code so it might have the memory intact but the error is definitely foreign. All I can think of is initialising it and start again so the program is wiped. Use the same code above but leave out the 4 (use another 0 in place of it) when you are following the init procedure. Good luck
  • Casio Master
  • 1,780 Answers
There is no error by the number 194 in the standard firmware. Your machine has probably had a special firmware implemented for a special use. This doesn't matter too much as they will usually program the same way for all of the usual things. Firstly, I'd perform a flag clear which will jump the machine out of any tasks that it is currently waiting on. It doesn't lose any data so it is safe to flag clear.
1. Turn the machine off at the power.
2. Turn the key to the 'program' position.
3. Hold down the RECEIPT FEED button (keep your finger on it).
4. Turn the power on.
5. After 3 seconds, let go of the RECEIPT FEED button and press SUBTOTAL once.
6. Wait for print then turn key back to REG mode.
You will need to sign on to use the machine. Normally, you press one of the clerk buttons just above the keyboard to sign on unless it has been programmed for PIN number logon (you should have been given the PIN numbers if this is the case).
Once you have logged on, try making a sale.
If the machine gives another error, check the receipt that just printed. Let me know what the number at the bottom of the receipt is. It should show 'FC' then a number.
Posted on Apr 20, 2014
flexion1
  • 737 Answers
SOURCE: error code 105 for casio te-2200
Hi.
We can check the memory allocation.
Turn key to program mode.
5 SUBTOTAL SUBTOTAL (must press subtotal twice).
This will print memory allocation.
Look down the printout and tell me what figures are listed under file numbers 16 and 40.
Mark
Posted on Jan 05, 2009
SOURCE: i have bought a second hand casio te 4500f and i
Are you going to keep the rest the same?
Logos are done in Program 2
2 subtotal 0132 subtotal enter characters press the CA/TEND or CASH or CA or the lower right hand button press subtotal
Posted on Oct 16, 2009
flexion1
  • 737 Answers
SOURCE: I have a te-4000f and I wish to change the prices
Hi. Turn to program mode. Type new price (NO decimal point) $11.20 =1120 press the item to be changed on the flat keyboard Press SUBTOTAL
Posted on Dec 06, 2009
Electroboy
  • 1780 Answers
SOURCE: We have bought a cafe and the second hand Casio TE
PGMX means the machine is trying to print a current program report. It may have been interrupted. Try this procedure to jump it back out:
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Turn key back to REG mode (you may need to sign on if asked)
If anyone needs a manual for a Casio TE-4000F cash register, http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Posted on Sep 12, 2010
Electroboy
  • 1780 Answers
SOURCE: i have a casio te
Ok. See if you can get rid of the buffer full error for a start. try pressing clear (C) then press Subtotal. You should see an amount on the display. Now press the ERR CORR/ CANCEL button. This should stop the sale that you are stuck in.
Turn the key to Program mode. If it gives error as you turn the key, then you haven't finshed in REG, turn back to REG and try to end the sale first.
If you see P01 on the display, it has worked and then do this:
1 SUBTOTAL 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL.
Now turn back to REG and try it.
If it still didn't work, let me know what happened, and I'll show you another method
If anyone needs a Casio TE-4000F manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Posted on Jan 31, 2011
Casio Te-4000F Error E050
You should first check that you entered the correct digit for check tracking and not scanning file when you typed in the init code. Check your init code by performing a flag clear. If that is ok, Print out the memory allocation (program 5) and make sure you have allocated memory for check tracking.
May 12, 2014 | Casio Parts Cash Register PC Desktop
Cassio TE-4500F
You have put too many items into a guest check (tab). Finalise (pay off) the check to free up the memory.
If anyone needs a Casio TE-4500 or TE-4000F programming manual, one of the users has it here:
Dec 04, 2013 | Casio Parts Cash Register PC Desktop
I'm tryng to change a drink name on a casio te-4000f and put the wrong letter in the drinks name, how do i delete the wrong character?
The decimal point deletes a character. If you have finished the programming, just program the name again and it will correct it.If anyone needs the Casio TE-4000F programming manual, try here:
Dec 04, 2012 | Computers & Internet
TE-4000F shows error code E053 and power failure issue
C-tech said he is helping with this problem. He'll sort you out
Feb 29, 2012 | Casio Parts Cash Register PC Desktop
Need to restore Casio te-4000f to factory settings. Advice?
The instruction manual is here. There is a way to reset the reporting data, if that is what you want. I don't see a way to reset all settings back to factory defaults, though.
Feb 11, 2012 | Computers & Internet
How do i take off a change amount that seems to have beeen programmed into my casio te4000f everytime i ring up a sale...
Try this:
Turn key to program 0 CASH SUBTOTAL Turn key back to REG
If anyone needs more information, the Casio TE-3000s, TE-4000F and TE-4500F manuals are here: http://the-checkout-tech.com/manuals/cashregisters/Casio5.php
Mar 20, 2011 | Casio Parts Cash Register PC Desktop
I have a casio te 4000f and it will not let anyone ring in when sub total pressed it is counting down in 1p also saying buffer full??? help
Jan 29, 2011 | Casio Parts Cash Register PC Desktop
Hi, I have a Casio TE-4500F and am having problems configuring the clerk interrupt function. If I Iog into the register using one clerk number say 1 - CLK#, as soon as I have pressed a PLU key to start a...
Are you new balancing before you try to log the second clerk on? Make sure you don't have the check tracking selected. You can use interrupt or tables, but not both.
If anyone is looking for a Casio TE-3000, 4000F, or 4500F manual, c-tech can help
TE-3000S operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_users_manual.html
TE-4000F, 4500F operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-4000F_and_TE-4500F_users_manual.html
TE-3000S, 4000F, 4500F programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Oct 19, 2010 | Casio Parts Cash Register PC Desktop
We have bought a cafe and the second hand Casio TE 4000f electronic cash register but it appears to have frozen so we cant enter any date. The display says PGMX and the amount 0.00 is displayed. Even...
Sep 12, 2010 | Casio Parts Cash Register PC Desktop
How do you program HST on my TE4500?
Which tax number has been set for HST? you have to set the rate on the correct tax number.
If anyone needs / looking for a Casio TE-3000, TE-4000F, TE-4500 manual, c-tech collective have them here:
Aug 31, 2010 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
69 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
