Question about Dell 3000cn Color Laser Printer
Paper Jam The printer says that theres a paper jam. But I have took out every part and physically looked inside and outside of the printer. I also shut down the printer and then restarted it 10 mins later. The same words keeping coming on the screen about a paper jam. What should I do?
  • 2 more comments
  • Anonymous Apr 07, 2008
    printer dispalys paer jam, there is no paper jam and it makes the grinding noise.
  • danu320 Sep 21, 2008
    I have the same problem and cannot find any paper stuck anywhere.  I called Dell and they told me to get a new printer because it cost more to fix- they said printer is only good for a couple of years.  I get this error:
    Paper Jam Reg
    077-900
    Open Reg Cover
    Remove Paper
    Any other solutions or how to look for a small piece somewhere- how about a part list so I can know where fuser is, etc.?
  • Anonymous Feb 10, 2009
    error 077-900 printer 3100cn
  • Anonymous Apr 21, 2009
    Same problem here. They say it needs a part but Dell won't even sell it to me. Just "buy a new printer" . I'd like to at least get the other 3 color cartridges out so I can use them in the 3000cn that is still working.
    Problem Solver:
I can suggest that the printer is trying to feed papers but it couldn't. check the feeding rubbers (Pickup rollers) and if neccessary, clean them up with soap and let them until they get dry. that should make it work.
cheers;
Posted on Apr 01, 2009
    Sniper:
  • 56 Answers
Check carefully, maybe you have just small peace of paper on the sensor actuator.I suggest to inspect whole path of paper.
Feed,transport,fuser.
Posted on Nov 02, 2007
Paper jam
there must be a little paper left from a jam or there is too much paper in the tray
Jul 12, 2010 | Brother MFC 240C All-In-One InkJet Printer
My 2600n laser printer had a paper jam in the outbox bin. I took the stuck paper out and had a look inside. I see no other paper jam but the printer keeps telling me I have a paper jam in the outbox. ...
There is a sensor flag (little black peice) that hangs down in the paper path as the paper exits. The flag tells the printer if the paper has made it out or not. That sounds like your problem. Just in case it is something else, her's a copy of the complete service manual for your printer. Start on page 90 (pdf page 113) and it goes thru the jam areas.
http://www.feedroller.com/Store/Service%20Manual/HP%20Color%20LaserJet%202600N%20(Q6455A)%20Parts,%20Service%20Manual.pdf
Nov 16, 2009 | HP Office Equipment & Supplies
Canon imageclass mf6530 paper jam error wont go away
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Paper Jam 0
I have this problem too but mine is intermittent. I believe it's a physical failure of the (likely) plastic gears of the feeding system (from when I "had" to pull a dozen pages out of the jammed feeder!)
Any physical 'trauma' like that it may have experienced? You might be like me - in the market for a new printer.
Apr 01, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Paper Jam
Double check when u remove the paper it may still have some left
Need to know the exact error
Thanks
Jaywizz
Oct 04, 2007 | HP PSC 1210 All-In-One InkJet Printer
Dell 3000cn Color Laser Printer Logo
364 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
