Just the top of screen is blinking how do i fix it
Ihave a windows eight computer and the top of the screen is blinking off and on can only type when color is in top of screen
    New Friend:
    Problem Solver:
  • 8 Answers
Have you recently installed any software, or made any changes to the screen resolution or other configuration changes? If so, then undo them and see if the problem goes away. The most likely hardware failure would be the video card, if your computer has one that's not built in to the motherboard. It might be worth the trouble to re-seat the video in it's slot on the motherboard, and to check all of the cable connections between the computer and the monitor to make sure they're all snug. If these things don't work or don't apply, then the problem is likely not something that you're going to be able to fix yourself, so a trip to the store where you bought it might be in order. Good luck!
Posted on Apr 20, 2014
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: stop mouse blinking when start open windows and over screen color resolution and size
make sure the mouse Ps 2 or the usb plug has a good seating if applicable or if its batteries that are good
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Posted on Jul 20, 2012
Ihave amitsubishi modle wd-65c9 tv ihave aprolmen with white and black spots yu replace dlp chip free for thay have prolmen for yeay
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 05, 2017 | Televison & Video
Ihave lines at the top of the screan on my tv but can still whach the tv modle code is UE40D5520RKXXU
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 24, 2017 | Televison & Video
Hitachi TV LED screen went black
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 12, 2016 | Hitachi Televison & Video
My Panasonic Plasma HD TV will not display a picture. The red light is blinking eight (8) times. What does this code mean and is it a quick fix? Thanks!
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. Otherwise, you might have to go through more than 4800 posts it contains.
Oct 28, 2015 | Panasonic Televison & Video
I am trying to on my IKON LCD red light bling but tv not on , ihave try through remote or manualy standby switch but no luck . before this lcd was working very fine since last three year.
These blinks are fault indications, and are called blinking codes. Count the number of blinks occur at one time switch ON. By these blinking numbers, you can get an idea about the faulty circuit stage inside the TV; which will make repair easy. If you're sound in electroncis. and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
Oct 23, 2013 | Televison & Video
Sony tv blinks more then 8 times ? how can i fix it
  1. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Aug 18, 2012 | Sony FD Trinitron WEGA KV-27FS120 27" TV
India mumbai on 27/10/2010 ihad purchased toshiba laptopl650 icould able recovery disc+opratig systm twice ihad been to service centre in andheri mubai first of edont this model itwills possible you go...
Is it still booting into windows so we can change key?My tech team and I can help lots with PC stuff it would begreat if you could ask any PC questions you have here so we can discuss itproperly http://www.mypcmates.com or we can fix it via remote
Nov 11, 2010 | Toshiba Computers & Internet
Computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Mar 06, 2009 | Sony VAIO VGN-CR220E/P Notebook
Techwood TWP4210 Plasma tv
a resistor has developed a dry joint or failed on the data connectors of the plasma panel,there are eight at the top of the plasma. An easy fix if you know what youa are doing,
Aug 24, 2008 | Televison & Video
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
