Question about Black & Decker Tools & Hardware - Others
Obsolete item Battery for FS360 Type 1 is obsolete? What do I do for a replacement?
Why I am being charged for Amazon Digital Services. I don't know what the service is for and want it stopped. Thanks.
1) Go online to find type of item for Amazon; when found, list any info you have: year purchased, receipt no. support dept.. Eventually, you will locate the product wherein "Support" should be able to assist. Provide photo if possible.
2) If have no PC, call Amazon directly & provide info as described above - "Support Dept."instructions as before. They should be able to narrow it down.
I, myself, followed these instructions for my Router, 2 years ago, and finally resolved the issue - even though my Router was already obsolete, but they were able to track down the info. Takes a little persistence.
Mar 08, 2016 | Computers & Internet
Are there any other rand of saw blades that fit a Delta 40-130 scroll saw? I understand delta blades are obsolete and can't even find the part number For reference. It is a pin type
i see scroll saw blades all the time at menard's and home depot.but if you search amazon.com they have lots of items and just may have them
Mar 21, 2015 | Delta Saws
What motherboard will replace a msi k7t turbo2?
This is an obsolete part; as such, you will have a hard time finding it at any retailer, whether brick and mortar or online. However, all hope is not lost-try E-bay
http://computers.shop.ebay.com/i.html?_nkw=socket+a&_sacat=1244&_trksid=m270&_dmpt=Motherboards&_odkw=&_osacat=1244
You will have to look for a board that supports S-Dram memory, because that is what your MSI K7T Turbo2 uses.
My advice would be to skip this entirely; I would replace the whole board/CPU setup, and pick up some memory. You can get an Athlon II quad core and mobo for $165.98 USD (Asus /AMD). Pick up 2 GB of Kingston DDR3 RAM for $56
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134790
and you essentially have a whole new system for $222
Just my opinion on this-I don't think that spending the amount of cash you would have to in order to replace an obsolete board is worth it.
You might try this, instead:
AMD Athlon II x2 Regor (2.8 Ghz, dual core) @ 56.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103688
ASRock M3A770DE AM3 AMD 770 ATX AMD mobo @ 59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148305
Total $174.97 + shipping USD
Given you 3 ways to go and my advice-good luck!!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
Crucial 2 GB Ballistix 240 pin DDR3 1600 Memory for $57.99
Feb 03, 2010 | MSI K7T Turbo2 Motherboard
Dell latatude D630 is docked/battery flashing 4 red 1 green
4 orange and 1 green can mean a battery malfunction, or it could be an indication that the battery is about to reach the end of its life cycle. When a battery is built, it has a planned expectancy. a date code is stamped in the electronics of the battery pack. as that date code is reached, the indicator lights on the computer let you know the battery (even if its working fine) is considered obsolete and needs to be replaced soon.
Nov 05, 2009 | Dell Latitude D600 Notebook
Audio output jack on the bell and howell filmosound 16mm
it's not a 1/4" phone or a 1/8" phono, so it must be an obsolete jack. if you can't find out the type, you can always replace them with a 1/4" jack.
Apr 29, 2009 | Office Equipment & Supplies
Broken Part. Need Replacement
If you refer to the oil filler plug, item #6 in the diagram linked here, it's listed as obsolete.
If refer to the intake filter, It's item #3 on the diagram, it too is listed obsolete.
http://www.mastertoolrepair.com/vpp0200604-vp0200604-p-14827.html
I would contact Master Tool Repair at 757-410-2879. They can cross the part to another once they know the thread size of the old part.
Mar 15, 2009 | Coleman Proforce 6 Gallon Air Compressor
I am trying to connect a Chauvet Followspot 400G to an Elation Sc
Just follow the details below to set your spotlight.
The TFX-FS360 utilizes 2 DMX control channels.
Channel 1 is for the colour.
Channel 2 is the dimmer.
1) Press the FUNCTION button until the DMX Mode LED turns on.
2) Press the UP or DOWN buttons until the starting channel address you desire is located on the digital display. eg 19
Regards
Jon
Feb 28, 2009 | Chauvet Followspot 400g with Stand
AMD Athlon XP Socket A processor
contact a local shop, we don't know here.
May 19, 2008 | Computers & Internet
GE 106789 Cool Touch Deep Fryer
called Rival,they have loads of MDP-1 power cords sets,just purchased mine today.(1800-323-9519).BTW,,When asking ,its listed as MPD-1 instead of MDP-1,(typo error).Its the same cord.
Jun 17, 2007 | GE 106789 Deep Fryer
Tools & Hardware - Others Logo
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
