Question about Pantech Cell Phones
Power button wont wrok on pantech marauder
My pantech marauder's power button has been broken for awhile, it wouldn't turn on without having to push something, such as a knife under it, then it would turn on. But it recently died, and wont turn on at all. Is there a way to turn it on?
  • Ali Santiago
    Ali Santiago Apr 20, 2014
    Ive done the vol + and vol - at the same time and it shows a screen that says "PDL DOWNLOAD.FASTBOOT. REBOOT. POWER OFF" i must use the power button to select. does anybody know of a way i can select without the power button?
    Problem Solver:
  • 20 Answers
Yes, you will have to repair the power button then it will be able to power back up.
Posted on Apr 20, 2014
Testimonial: "How do i do that o.o? Im sorry, im not a very big tech person :c."
  • 6 more comments
  • Balentine Tech
    Balentine Tech Apr 20, 2014
    there are tortaials about how to replace the power button on sites like youtube
  • Balentine Tech
    if you cant find one ask me and i will try to find a good site
  • Ali Santiago
    I can't find anything. And what i have found didn't work.
  • Balentine Tech
    i will be back with you in a hour about this problem
  • Ali Santiago
    okay, thanks
  • Balentine Tech
    if you have any more plobems tell me because it could be another tthing wong with it like hardware mount function
  • Ali Santiago
    Nothing else that i know of. When it was on, it worked just fine. Only thing wrong is i can't turn it on.
  • Balentine Tech
    can you give me model, serial, and everything else? Tell me at superminecraftbros132@gmail.com or you can contact me thu my website: balentinetech.webs.com
SOURCE: Sony Ericsson w810i
my phone screen is broken which buttons do i push to put it on vibrate?
Posted on Jun 16, 2008
mombodetski
  • 16 Answers
SOURCE: my power button doesnt work anymore
Mine turns on when I plug the charger into it. Have you tried that?
Posted on Jul 04, 2010
  • 4 Answers
SOURCE: power button 6303 broken
the IC Power is broken or..
Reflash Your Phone
Posted on Feb 07, 2010
SOURCE: my power button is broken and my phone wont turn o...
plug in the phone to charger. after you see the verizon sign, wait two seconds and unplug it quickly. it should turn on.
Posted on Mar 03, 2011
SOURCE: how to turn on the htc amaze without the power button
Dude take off the case like your about to take off the battery out.Check the top of you phone if the left piece of your phone is gold it broken.
Posted on Jul 17, 2012
How do i set the time on a pantech p5000?
Date and Time Settings Pantech Marauder
Date and Time Settings - Pantech Marauder™ [Device-Specific Instructions]
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Nov 01, 2015 | Pantech Cell Phones
The email count does not clear out
Do you have your Marauder's email system linked to your home or work PC? I have posted a link along with this response which will take you directly to a web site showing you how to delete your troublesome emails ..
Delete an Email Message Pantech Marauder
Mar 27, 2014 | Pantech Marauder - 4G LTE
Power button stuck
First try removing the battery reinstalling it and attempt to power back on - this will make sure that no app has hung up effecting the power on/off button. I have had this happen to me before. Make sure there is no built up gunk along the top and bottom sides of your power on/off button which could prevent the button from going in far enough when pushed. I used a thin razor blade to preform that task. If those two things dont bring you any results then your phone truly has problem that will require and master wipe with the power button and down volume control
Mar 22, 2014 | Pantech Marauder - 4G LTE
Power button not working
get repair it. Or change the button. thankU!
Sep 22, 2013 | Pantech Marauder adr910lvw
How do I change the answering method on a pantech marauder
I'm not sure on how to do that. However here is a link to the manual that might be able to help you out. Hopefully this helps.
Pantech Marauder manual.
Feb 06, 2013 | Pantech Marauder - 4G LTE
Need unlock code for a Pantech Marauder phone
If it is just a simple 4-digit code, and you won't get locked out for guessing incorrectly, then start with like: 0000 and go from there. If it is Verizon, then try calling them from a different phone, and maybe they know some sort of reset code or something.
Nov 18, 2012 | Pantech Marauder - 4G LTE
Wont power on when push power button
Have the set inspected for any damage and have the power supply also inspected if set total dead.
Sep 02, 2012 | Emerson Televison & Video
How to turn on the htc amaze without the power button
Apr 13, 2012 | HTC Amaze 4G
Is there a way i can turn on my pantech jest without using he power button because the power button wont work due to water damage.
I accidentally dropped my phone in water and then the power button (red) wouldn't work. But then I took out the battery, plugged it in the charger, and then replaced the battery while it was still plugged in. It worked!
Nov 10, 2010 | Pantech Cell Phones
Sony Ericsson w810i
Apr 14, 2008 | Sony Ericsson W850i Cellular Phone
Cell Phones Logo
224 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
