Question about JVC HD-52G786 52" Rear Projection HDTV
THERE IS NO SOUND
MOVED THE TV NOW THERE IS NO SOUND, iT WILL NOT LET ME CHANGE THE SOUND EFFECT
    Scholar:
  • 195 Answers
Try a hard reset by unplugging the set for 30 secs. Then, go into the remote and make sure speakers have not been turned off.
Posted on May 08, 2014
How do I change my audio setting
It depends on what you want to change about your audio setting. My cable box remote has two audio settings: one for changing the SAP language sound from English, to Spanish or French; and a setting that changes two separate audio functions: one changes the broadcast sound from Dolby Digital (TM) sound to regular stereo sound, and the other will allow using either a fixed setting (cable box sound level is at a fixed level allowing one to use the sound control on the TV, or other audio receiver), or a variable setting (allowing the use of the cable box to adjust the audio level).
My Sony TV control also allows me to adjust the tv's audio treble, bass, balance, and special effect sounds, and if needed, to turn the tv speakers off. Hope this is helpful..................Gary
Apr 23, 2014 | Sanyo DP26640 LCD TV
HK AVR 125 display strobing and no sound, even in headphone jack
Hi...
Find someone that does TV or audio repair and have them open it up. A cable assembly may have loosened during the MOVE.
Cheers
Jan 30, 2014 | Harman Kardon AVR 125 Receiver
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Oversized picture problem
Several possibilities, if you use a set top box to get your signal like a cable box or satellite receiver they will have settings that effect picture size. It could be a high voltage problem inside the TV causing an effect called blooming, if that is it you can usually change brightness and or contrast and see the picture get smaller and larger. I don't recall that set having any customer settings that could give that symptom.
Sep 11, 2009 | Mitsubishi CS-40503 TV
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
No picture, but has great sound
Older television have components that are designed to last for about 10 years. slight movements can cause failures in old Capacitors and loosen connections.
Might sound weird but seriously give the thing a good slap on the side after it has warmed up. if there is any effect AT ALL. take it to a repair man. if not your set may have simply bit the dust and now requires more servicing costs then a new set.
Nov 07, 2007 | Sony KV-36FS100 36" TV
Sound
You may have your audio presets on your DVD too low. check your menu to make sure those presets are correct. As for Surround Sound it is a sound technique that involves having multiple speakers to give the impression of moving sound, not just hearing from the left or the right as in stereo, but hearing the way you are exposed to in real life sound moves around you this combines the doppler effect from many directions at once, example: as a car move towards you with its horn blowing the sound gets louder as it passes you the sound gets lower however, each of your ears hears the sound diferently, thats how come you can tell if the car is to your left or to your right vs coming straight at you and as it passes you, you can tell if the car is on your left or right from your rear. Surround sound is an attempt to do this without actual movement. I hope this helps.
Sep 07, 2007 | Akai LCT3201AD 32 in. LCD Television
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Diagonal lines
Hi It's difficult to be sure without being able to see the lines myself, but what it sounds like is some stray RF is getting into your video signal. Although your cables are supposed to be shielded, this is a common problem. The first thing I would do is move the cables or cable you are using, in relation to any power cords hanging down behind your equipment while someone watches for the lines to change or dissapear, and is that has no effect, then if possible change the position of the VCR in relation to the tv, so that if for example it is under the tv, move it to the side, or farther away, and the lines may very well dissapear. That problem is due to a common interaction between the tv and vcr where there is not enough shielding, usually inside the bottom of the tv set. Hope this helps, good luck!
Feb 11, 2007 | RCA VR546 S-VHS VCR
JVC HD-52G786 52" Rear Projection HDTV Logo
82 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
