Question about Garden
I need a gas tank for a royal tiller - Garden
  • 88 Answers
Try PartsTree.com in Austin, Tx. They seem to have hard -to-find items.
Posted on Jun 01, 2014
5 Suggested Answers
  • 112 Answers
SOURCE: Statesman Tiller
without knowing if its a briggs and straton or tecumseh engine ( I assume Briggs) the carb is where the throttle and gas line connect to. carb will need to be rebuilt most likely and tank will have to be removed to be cleaned. you can email me and I could do it for you I am in wisconsin kerryjonjon at yahoo.com I am the most reasonable in this area. I could do carb and tank if you want.
Posted on Jul 15, 2009
  • 8 Answers
SOURCE: 8.50 Torque Rating Dual Rotating Tine Tiller: left old gas in tank and need to clean and start...
First step remove old fuel
Should be a turn off valve on bottom of fuel tank. Then go to the Carburetor were the fuel line runs to. on bottom is the float bowel. Remove the bolt in center of this bowel. drain old fuel out. Then turn on your fuel with bowel off. flushing the line. If not fuel runs out. Lightly tap the float. If still no fuel. Turn off fuel. Remove the float under the float is the needle and seat. Remove the needle if did not fall out. Clean or replace the needle. Then replace float and bowel. Turn fuel on check for leaks. remove spark plug check for spark. Should have a nice bright blue spark when you crank it. If so put a little fuel in spark plug hole. Give a pull. Or if you want dip the plug just to the end of threads in fuel. Replace plug . Should start right up.
Posted on May 21, 2010
  • 6468 Answers
SOURCE: removing a gas tank from a Big Red Troy Bilt Tiller
remove the bands the other bolts are under the tank
Posted on Apr 21, 2012
randyprevost
  • 887 Answers
SOURCE: i need a gas tank for a rear tine tiller 917293480
Then, go buy one. Try looking at sears.
Hope this helps.
Posted on Aug 31, 2012
2 year old gas in tank. tiller won't stay running
When you drained the gas from the gas tank did you also take the carb apart and clean it. There should be a bowl that the fuel line from the gas tank goes to. There is a float in that bowl that has to go up and down to regulate how much gas goes into the engine. You may have a build up of varnish from old gas on the piece that the float moves up and down. Also there should be an idle jet that you screw in and out to adjust the idle. That also could be junked up.
Apr 18, 2013 | Ariens 902032 - 12"/22"/24" 6HP/169cc...
I need a gas tank for a rear tine tiller 917293480
Hope this helps.
Aug 31, 2012 | Sears Garden
Tiller will not continue to run. It has good spark. It will start if primed through the carburator but once the prime burns off it dies.
If fuel sits in the gas tank 3 months, the fuel deteriorates and it gums up the filter in the tank. You need to put stabil in the tank. This has happened to me over and over. It is best to dump out the gasoline if you don't use the tiller within one month. Some people who use chain saws commercially dump all the gas out every day and start over the next day. The symptoms are the tiller won't run at high speed at first, then as it gums up more
it won't run even at low speed, then becomes hard to start.
The gum is hard to see. Pull out the gas line to get to the filter and change the filter. Filters are only 3 or 4 dollars at hardware stores.
Jun 01, 2012 | Honda 25cc 4-cycle Mini Tiller
Removing a gas tank from a Big Red Troy Bilt Tiller
Apr 18, 2012 | Garden
Does this use mixed gasoline or regular gaso;ine
If your model does in fact have markings on it or in the manual indicating it is a 4-cycle tiller you need to put straight gas in the gas tank. It will also have an oil plug/dipstick on the motor that you have to check to make sure it is full of oil. The oil should be checked every time you fill the gas tank for the safety of your motor.
Apr 14, 2011 | Mtd Craftsman 4Cycle Mini Tiller
My 3 yr old put sand in my tiller's gas tank. Can it be fixed?
Hi Lisa,
Hopefully it wasn't running.
You need to:
  • drain the tank
  • remove the tank
  • rinse it out (with more gas), including the hoses until no more sand is evident
  • reassemble
Compressed air can be useful in dislodging any sand remaining in the tank.
Pouring the gas through a paint filter will trap the sand so the gas can be used.
Best regards
Mike
Mar 24, 2011 | Craftsman Garden
Gas tank leak
The gas tank would go with the engine. Find the engine number (Briggs & Stratton?, Kohler? ) You can order it online from Briggs & Stratton parts, or like Jack's small engine, or your local mower parts supply. Common poblem with these plastic tanks.
Jul 19, 2010 | Troy-Bilt Pony Garden Tiller
Statesman Tiller
Jul 11, 2009 | Garden
Fuel problem
take the gas cap off and look into the tank and see that the fuel filter is on the bottom of the tank and still secure to the fuel line.
Your tank will be slightly pressurized be sure your gas cap gasket is there and pliable.
same for your gas lines be sure they are relatively soft and dont crack easy if you move them?
try these couple items and see if any will help the cause
Jun 10, 2009 | Mantis 2-Cycle Tiller
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
