Question about Refrigerators
How do i fix my automatic ice maker? A bag got frozen in it
A plastic grocery bag got stuck in my automatic ice maker in my freezer. Ive noticed a frozen puddle in freezer and water in fridge too.
  • 2,372 Answers
Defrost it and pull the bag out
Posted on Apr 20, 2014
  • Any way to remove the ice maker only? Don't want to lose all my good while I defrost.
How to remove plastic bag stuck in ice maker
Depends on where the bag is stuck at, just frozen or got wrapped around the cube eject mechanism....if its just frozen then get your hair dryer and melt the ice around it. If it's wound around the mechanism you'll have to remove it from the freezer and after you get it out defrost it and just try and pull the plastic out don't pry on it with anything. Most ice makers are really pretty easy to get out, they just plug into the back of the freezer
Jul 14, 2014 | Kitchen Appliances - Others
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
Aug 03, 2009 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Ice maker not working
Usually when this happens the water line in the freezer is frozen. If this is the case, defrosting the freezer should free it up and all will work again.
Aug 02, 2009 | Refrigerators
Ice cube tray overflowing-not shuting off automatically
Yes that is a plastic extension for the icemaker shut off. When replaced the new one should be secured with two small zip ties. You can use the ice on/off button to shut the icemaker off manually in the mean time. When ice is displayed in the panel it is on and when it is off so is the icemaker.
Jul 20, 2009 | Sub-Zero 650 / O Bottom Freezer...
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
GE Refrigerator Series
Your Ice maker may have a defrost heater stuck and causing to much heat in the freezer. Feel around the bottom of the ice maker see if its warm Not too close it can burn you if its on all the time. If this is the trouble remove it and when you unplug it see if the temp goes back to normal in the freezer.
Please get back to me and let me know if this helped or you still have a problem. Please rate me accordingly and good luck.
Mar 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Undependable freezing - sometimes will, sometimes won't!
High room temperatures will throw this unit off BIG TIME. Just to give you an idea how sensitive the freezer bowl is - if you run cold water along the freezer bowl before putting your ingredients in, the COLD water is enough to unfreeze the bowl! Don't remove the freezer bowl from freezer until you are immediately ready to begin mixing - not 5 minutes earlier.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Freezer Drawer Stuck
Our 550 bottom freezer drawer froze shut earlier this week and the motor made an unusual sound, like it was working too hard. Two of us eventually were able to open the drawer to find that it had frozen shut due to a leak which filled the ice tray solid and then adhered to the actual door, freezing it shut. We emptied the fridge and freezer, turned the control dials down to 0, but neither the motor nor the light would go off. We finally killed the circuit breaker to get the appliance to shut down. It's cleaned and defrosted and we noticed that the gasket has torn in three places, two on the fridge door and one on the freezer door. The freezer door could be from our tugging, but the refrigerator door is normal wear and tear. We filled the tears with some kind of putty and when it is dry we will start everything up again. This is not the first problem of this nature we have experienced with our subzero 550, but it is the most dramatic. Each previous time we have called a repair man out and he has been unable to fix it.
Aug 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
