Question about Ridgid Garden
Want to know is there just one place you drain the oil from? And what is the best oil to use, cannot locate manual
Rigid 3300psi, 2.6gpm. Want to make sure I do all correct steps in changing oil and getting ready for spring use
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Look for the lowest bolt on the machine. there may be two, use the most conveniant.you may have a special plastic tube if not just remove bolt drain and fill with normal motor oil that u use in your car
Posted on Apr 21, 2014
Rigid 3300psi Pressure Washer chokes after engine warms up. Then looses water pressure. What is the problem and can I fix it?
if the engine slows then so will the pump... and so will the pump power.
engines are all the same and so just google "servicing engines"
an engine requires fuel - air - ignition and compression......
if your engine starts and runs then it must have reasonable compression so check / replace / clean the fuel and air filters...
check the condition of the spark plug / clean it / replace it
after these basic checks you move onto measuring the compression and checking the carburettor which requires a level of skill you may not have
oh, check the oil too !
if you have a make and model of engine (not pressure washer) the manufacturer may have service kits and service manuals... briggs and stratton / honda / tecumseh (you'll be lucky) / sumec linhai
Aug 30, 2013 | Legacy Extension,angled Rigid - LEGACY
1981 Kawasaki CSR 650 engine oil drain plug location
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1981 Kawasaki CSR 650 engine oil drain plug location Google Search
Oil Change 1980 Kawasaki KZ550 am not bike mechanic
Kawasaki KZ650 Service Manual
OEM Parts for Kawasaki
Kawasaki KZ650 B2 Owner Manual
Nov 11, 2017 | kawasaki Motorcycles
2009 HONDA METROPOLITAN GEAR OIL DRAIN PLUG LOCATION
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2009 HONDA METROPOLITAN GEAR OIL DRAIN PLUG LOCATION Google Search
Honda Ruckus Gear Oil Change
Honda CH80 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CHF50 2007 Metropolitan Owner Manual
Sep 08, 2012 | 2009 Honda Metropolitan
1988 Honda VT 800 engine oil drain plug location
1988 Honda VT 800 engine oil drain plug location Google Search
How To Do An Oil Change On Honda Shadow Spirit 750 Part 1 Tools And Parts...
1988 Honda Shadow Service Manual Vt 800
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Jun 16, 2012 | 1988 Honda VT 800
1997 road king engine oil drain plug location
Touring engine oil drain plug is on the left hand side front of the oil pan facing the front.
May 23, 2012 | Harley Davidson FLHRCI Road King Classic...
2011 Honda Activa oil drain plug location
Hi, Skamin92 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
2011 Honda Activa oil drain plug location Google Search
How to change Engine oil on 2012 Honda Activa 110 CC
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda activa 2009 Owner Manual
Aug 20, 2011 | 2011 Honda Activa
How do I change the oil on a Porsche 911 Turbo? Anything I sould know?
  • Jack up your Porsche using a floor jack and place the car securely on jack stands at all four corners using the factory jacking points.
  • 2 Place an oil container under the oil drain plug of the motor.
  • 3 Using an 8-mm allen socket, remove the drain plug at the bottom of the oil pan.
  • 4 Let the oil drain thoroughly--this will take about 20 to 25 minutes.
  • 5 Once all the oil is drained from the engine, install a new drain plug along with a new aluminum sealing washer. Tighten the drain plug to 37 lbs .
  • The oil filter cartridge is located in front of the oil pan on the right side. With an oil filter removal wrench, unscrew and remove the cartridge. Be careful of spilling oil.
  • Install a new oil filter cartridge and O-ring. Before installation, run a bead of oil around the O-ring to lubricate it. Torque the oil filter cartridge to 19 lbs.
  • Pour new oil into the oil filler neck located in the engine bay. 1998 to 2001 911s (996) take 8.5 quarts, and 2004 and up take 8.25 quarts. Newer 911s (997) take 9 quarts. When filling the engine with oil, pour in 8 quarts and then use the dipstick to get the amount of oil exact.
  • Lower the car off the jackstands.
  • Dec 19, 2010 | 2000 Porsche 911 Carrera
    Hi. I have 2007 Mercedes GL450 , Can you help me with oil change and oil filter change.Please tell me How to do it properly? The nearest Mercedes service is over 500 km. thanks alot, A
    BEST TO LET DEALERSHIP CHANGE ENGINE OIL.YOU NEED A DEALERSHIP OIL FILTER.YOUR OIL FILTER INSIDE A HOUSING ON FRONT SIDE OF THE ENGINE. CHANGING YOUR OWN OIL NOT HARD.YOU NEED 9 QUARTS OF OIL LOOK INSIDE GLOVECOMPARTMENT FOR OWNERS MANUAL TO SEE WHAT TYPE OF ENGINE OIL YOU NEED TO USE AND HOW MANY QUARTS.IF YOU DONT CHECK READ MANUAL TO SEE WHAT OIL TYPE AND QUARTS YOU NEED. IF YOU BLOW OR DAMAGE THE ENGINE WARRANTY WILL NOT COVER THE ENGINE.FIRST OF ALL TO CHANGE ENGINE OIL YOU CRANK VECHICLE UP LET IDLE FEW MINUTES TO THIN OUT OIL THEN YOU TURN OFF ENGINE. YOU NEED TO RAISE VECHICLE USING THE FACTORY JACK.USE JACK STANDS. LOOK IN OWNERS FOR CAR JACK LIFTING LOCATIONS TO KEEP FROM DAMAGING ROCKER PANELS. AND PLACE A DRAIN PAN UNDER THE OIL PAN. UNDER THE VECHICLE.YOU NEED A WRENCH TO REMOVE OIL PAN DRAIN PLUG.WHEN ALL THE OLD OIL DRAIN OUT IN THE DRAIN PAN.SCREW BACK IN THE DRAIN PLUG TIGHTEN IT DONT OVER TIGHTEN STRIP THREADS.THEN YOU NEED SOCKET TYPE OIL WRENCH YOU USE WITH A 3/8 RATCHET WRENCH REMOVE OIL FILTER HOUSING.PLACE RAGS AROUND THE OIL FILTER HOUSING TO CATCH OIL SPILL. YOU WILL NEED TO GO TO THE DEALERSHIP FOR THE OIL FILTER AND FILTER HOUSING O RINGS. ONCE YOU GET NEW OIL FILTER AND O - RINGS INSTALL THEM IN THE OIL FILTER HOUSING.LOCATED OIL FILLER CAP ON VALVE COVER UNDER THE HOOD.REMOVE OIL FILLER CAP.POUR OIL IN ENGINE USING A FUNNEL.ENGINE HOLDS ABOUT 8.5 TO 9.0 QUARTS OIL. BUT LOOK IN THE OWNERS MANUAL CHECK HOW MANY QUARTS ENGINE NEED.CHECK OIL DIP STICK OIL LEVEL SHOULD BE ON THE FULL MARK ON THE ENGINE OIL DIP STICK.TO BE ON THE SAFE SIDE BUY 10 QUARTS OF OIL FOR A EXTRA.DONT OVER FILL MAKE SURE YOUR OIL LEVEL CORRECT.OIL DRAIN PLUG AND OIL FILTER TIGHT BEFORE CRANKING THE ENGINE.LOOK IN THE OWNERS MANUAL FOR OIL DIP STICK AND LOCATION.
    Nov 05, 2010 | 2007 Mercedes-Benz Mercedes Benz Gl 450
    1)Removal of front tire and 2) location of oil drain plug
    Hi, Obrien14 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
    2005 Suzuki M50 Boulevard Remove the wheels Part 1
    How to change the oil on 2003 Suzuki Intruder Volusia
    Suzuki VL800 Service Manual
    OEM parts for Suzuki
    Suzuki VL800 Owner Manual
    Jun 13, 2017 | 2004 Suzuki VL 800 Volusia
    How to change engine oil?
    You can't see it from the top because the oil pan and drain plug are on the bottom of the engine. You will probably have to jack up the car in order to crawl underneathand reach the drain plug.
    You should change the oil when the car is cold, otherwise you'll end up with hot oil spilling onto your hands. You'll also need a pan that holds 2 gal of liquid and place it under the car beneath the drain plug.
    Remove the plug, drain the oil, replace the plug. Remove and replace trhe filter. then refill with oil. Do not over fill
    May 24, 2009 | 1988 Toyota Corolla 4 Door
    Garden Logo
    97 people viewed this question
    Top Ridgid Garden Experts
    protojexxx
    Lakeland Appliance...
    Are you a Ridgid Garden Expert? Answer questions, earn points and help others
