Question about Pioneer DEH-P4100
Light blue att wire whats it for
I want to know what the att wire is for on the wiring harness
mixmaster
  • 626 Answers
SOURCE: Searching for wiring harness sequence.
Found a service manual here, but you have to pay for it (only 4.95 USD). It has the wiring block specs you are looking for.
http://www.smpcshop.com/FH-P5000MP-p-3345.html
Best of Luck.
Posted on Nov 04, 2007
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
nuwan chinth
  • 111 Answers
SOURCE: dehp5800mp wire harness
orange /white wire is power antenna wire i think.is your setup working????????.let me know the status..
Posted on Jan 06, 2009
  • 4 Answers
SOURCE: Trying to install Plan Pioneer DEH-1100 into 1988
yellow is continous power
red in ignition power
black is your ground
and blue ir a remote wire
Posted on Aug 16, 2009
Need to know the color of each speaker wire on the speaker factory harness
1995 Ford Explorer Car Stereo Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jun 27, 2012 | 1995 Ford Explorer
As I'm driving the volume will decrease and the screen at the bottom right would say att. What can I do?
Att is the quite mode, Press the volume button down it will turn off att Mode, That is for when your on phone or something, Then you can mute it kind of.
Aug 14, 2010 | Pioneer AVIC-Z2 Car DVD Player
2002 toyota rav4, what is ACC on harness
The acc wire is the switched + on this diagram
2002 Toyota RAV4 Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Ignition Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Dimmer Wire: Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope this helps
Feb 03, 2010 | Buck Toyota Rav4 2003 Stereo/radio...
Need to know how to hot wire ignition.what color wires do i use?
1991 Ford F150
Vehicle Battery Positive Wire (+): Yellow
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Red/Light Green
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): N/A
Vehicle Second Ignition Wire Location: N/A
Vehicle Accessory Wire (+): Gray/Yellow
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): N/A
Vehicle Second Accessory Wire Location: N/A
Automobile Engine Starter Wire (+): Red/Light Blue
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): N/A
Automobile Second Engine Starter Wire Location: N/A
Factory Anti-Theft System: None
Factory Anti-Theft System Type: None
Car Key Sense Wire (-): Black/Pink
Car Key Sense Wire Location: At Steering Column Harness
Car Neutral Safety Wire (+): N/A
Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): Tan/Yellow
Car Tachometer Wire Location: At Ignition Switch Control Module in Driver Fender Well
Car Speed Sense Wire: Gray/Black
Car Speed Sense Wire Location: Pin #3 at PCM Mounted on the Firewall
Car Parking Lights Wire (+): Brown
Car Parking Lights Wire Location: At Headlight Switch or Driver Side Kick Panel
Car Brake Lights Wire (+): Green
Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): Black/Pink
Car Reverse Lights Wire Location: At Switch on Transmission
Car Horn Wire (-): Blue
Car Horn Wire Location: At Steering Column Harness
Sorry friend, this is as far as i can go to tel you how to hot wire the ignition. But with the color codes you should be able to figure it out, Good luck and keep me posted.
Jan 23, 2010 | 1991 Ford F150
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
The wiring on the 8 pin harness has come apart
Red,black,orange,pink. bottom is yellow,hole,green,light blue/yellow
Apr 10, 2009 | Kenwood KVT-617DVD Car DVD Player
I need to know what color are for what on my radio wire harness
Not for sure if I can help.Someone forgot the golden rule.NEVER CUT THE WIRING HARNESS.I dont have the wiring scematics in front of me but the older models had RED for power,BLACK for ground,and the wiring going to the spreakers should be an off color running together going to the speakers.Probably has a six speaker system.Hope I helped.
Feb 03, 2009 | 1994 Chevrolet Camaro
Cut harness from stereo in 1990 corolla dx sedan
did u know that they make a harness for your car that plugs into your factory harness and then adapts to your aftermarket radio? for the lights, you have blown the interior light fuse, it may be the same fuse as the cigar lighter.Below is your radio wire colors and what they do.
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Radio Switched 12V+ Wire: Gray
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: 4′
Rear Speakers Location: Rear Deck
Dec 19, 2008 | 1990 Toyota Corolla
Pioneer DEH-P4100 Logo
26 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
