Keyboard refuses to accept commands
It just emits 3 short beeps when any button is pressed -- "manual", "program", "quit", or anything else. It does not switch into the appropriate mode. The stored program continues to work, but we cannot reprogram it or override it. I found a fried bug that oozed all over some pins on one of the chips on the circuit board. Scraping that off did not resolve the problem. It is slightly possible that this shorted the chip out fatally.
  • 14 Answers
SOURCE: continuous beeping sound
you can see out put in screen if no you must chek ram's
else you should remove your keyboard and mouse in test ather
Posted on Dec 16, 2007
Destinova
  • 46 Answers
SOURCE: dell webpc,,2 short beeps and keyboard error
Does the keyboard still work? more often then not there is either something in the socket OR it is a bad socket.. Now depending on the machine you could try reseeting the configuration data in the bios.. I have seen this work with limited success Good luck
Posted on Mar 07, 2008
SOURCE: looking to try to fix
The sbm1040 chip is available from Digikey. It is a 40volt, 10A, rectifier diode. The previous chip suggested MBR2515 is a 15V, 25A Chip.
Posted on Feb 24, 2009
  • 357 Answers
SOURCE: short but rapid beep code when powering up emachine
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Posted on Feb 26, 2009
Saigua
  • 981 Answers
SOURCE: Where can i find the Schematics for this
Leisure Bay Spas' engineering department.
Posted on May 18, 2010
How do I sinc my fireplace remote ecs1001-a two button to fireplace
Each transmitter uses a unique security code. It will be necessary to press the LEARN button on the receiver to accept the transmitter security code upon initial use, if batteries are replaced, or if a replacement transmitter is purchased from your dealer or the
factory. In order for the receiver to accept the transmitter security code, be sure the slide button on the receiver is in the REMOTE
position; the receiver will not LEARN if the slide switch is in the ON or OFF position. The LEARN button in located on the front face
of the receiver; inside the small hole labeled LEARN. Using a small screwdriver or end of a paperclip gently press and release
the black LEARN button inside the hole. When you release the LEARN button the receiver will emit an audible "beep". After the
receiver emits the beep press ANY transmitter button and release. The receiver will emit several beeps indicating that the transmitter's code has been accepted into the receiver.
Oct 29, 2012 | Skytech 1001-A Fireplace Remote Control...
Does not overwrite old codes, just keeps accepting new ones. How can I clear all existing codes?
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Jan 27, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
Good lock
Good unlock
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
Beeps emitted during power on POST. Beeps pattern as the following. While press power ON button, 3 short beeps, then 8 short beeps, repeat the same for a while, then power off. I have removed all...
Hello
This could be a bios setting problem.Try resetting the bios to default.
Remove memory sticks for a minute and then reinstall.
Here is a link for the manual explaining the beepcodes and what they mean.
Also it explains how to reset the bios.
http://download.gigabyte.us/FileList/Manual/motherboard_manual_ga-g33m-s2l_e.pdf
Hope this helps
Dec 16, 2010 | Gigabyte Matx Intel G31 775 DDR2-800...
I was previously surfing the net using Chrome and I had opened many many tabs.. My laptop (Fujitsu Lifebook S Series - S6420) then hung/hannged and I couldn't do anything so I held down the power button to...
Your beep codes are..
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card .
So looks like a display problem, have you tried any of the recovery/restore options available when you press F8 on boot up
Sep 30, 2010 | Intel S6240 Notebook
How do you get rid of the beeping noise when you dial on a Toshiba Business Phone - Model #DKT3210-SD?
Dial Pad and Button Beeps
Digital telephones can emit a “beep” sound whenever a dial pad or feature button is pressed. The “beeps” are On by default. Follow these steps to turn the “beeps” On or Off on 3000-series DKTs.
1. Press 3+6+9+Hold(simultaneously).
2. Press 0.
3. Press Feature Button 1 (FB1) to toggle On/Off.
FB1, LED On: buttons beep.
FB1, LED Off: buttons do not beep.
4. Press hold to set the option.
5. You must also go off-hook, then on-hook to exit the program mode.
Mar 03, 2010 | Toshiba DKT 3010 Corded Phone
Our Powerbolt 1000 will not delete old codes.
Are you certain you're programming new codes properly? It should just overwrite the codes when new ones are programmed. If you are doing it right, then I'd say you may want to have the unit repaired/replaced...
To program new codes (just in case):
Push the program button on the control board once for memory 1 OR twice for memory 2. Enter a 4-8 digit code. Push the lock button to end the entry. The unit will emit a 2-second long beep if your code is accepted. (If it doesn't beep, you were too slow. Try again.) Repeat the process for the other memory position.
Jan 30, 2010 | Weiser Lock Powerbolt 1000 Lock
The lock is installed need to know how to program
First make sure you have the door handing set properly. Retract the bolt manually if extended. Now press the lock button... If the unit extends the bolt, then you're good. If not, switch the jumper position on the control board. If it's covering pins 1&2, move it to cover 2&3 or vice versa.
To program code #1..
Push the program button on the control board once. Enter your 4-8 digit code. Push the lock button to end the entry. The unit will emit a 2-second long beep. If it doesn't beep, you were too slow. Try again.
To program code #2, press the program button on the control board TWICE. Enter your 4-8 digit code. Push the lock button to end the entry. As before, the unit will emit a 2-second long beep when a successful entry is made.
Test your codes with the door open just to be sure.
Dec 16, 2009 | Weiser Lock Powerbolt 1000 Lock
TV does not turn off with remote or pressing the power button. Can it be fixed?
Yes - Likely one of the front panel buttons is stuck on (shorted or changed value) and the TV refuses to accept any other commands until that stuck button is fixed - What is the model #?
Sep 27, 2009 | RCA Televison & Video
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
