Philco gud808 how to clean the dust after wash and dry
My dyson animal ball dc15 smells really bad how do I clean it
I've throw my disclaimer up front: This is Dyson's official response.
Do not use detergents, polishes or air fresheners to clean the clear bin. Do not put the clear bin in a dishwasher. Do not immerse the whole cyclone unit in water or pour water into the cyclones. Clean the cyclone shroud with a dry cloth or dry brush to remove lint and dust.
Which I didn't follow and happy I didn't...
I have a Dyson DC15 but if you youtube your model + "complete cleaning" I was able to follow their instructions. And I washed EVERYTHING - the bin, on mine at least breaks down the opaque plastic and clear. Washed all of those. The main brush (cut the hair out) and washed it along with some of the hoses I thought would dry out and the HEPA filter has manufactured instructors.
Just used a light dish soap, warm water and bottle brush - than let it dry for about a week sorta shaking everything when I remembered. Which was just increase the surface area of any remaining water and ensure 100% it was dry before putting it back together. Just felt if it was wet it would collect dust the first use and get dirty quicker.
I liked this video included because he warns of a particular seal I didn't have that would warp if it got wet. So just be aware of what you're doing watch some quality videos and take your time its not difficult but their like puzzles and you'll need some patiences to get it all back together.
Oct 03, 2015 | Dyson Vacuums
String stuck in washing machine
you need to unwind the string and any other blockage can be hard
sometime their is a need to dismantle and clean out all the bushes and bearings from threads hairs and also strings,
Mar 04, 2015 | Indesit & Philco Washing Machine Drive...
How to clean dyson dc14
Try cleaning out the cyclone assembly and dust compartment
Jul 04, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Where can i get electronic spare Parts for Philco GUD808e washing machine
Best I suggest is contact manufacture for dealer near you
Apr 29, 2014 | Washing Machines
Philco washer doorlock
The door switch or latch could be jammed and you might have to try and check for the end of the washing cycle to get door latch released.
check this link: Door lock
Oct 03, 2013 | Washing Machines
How do I clean filter on black&decker DustBuster pivot 18v
(The below worked with my 9.6v version - I assume the others in the pivot range will be similar).
If you open the lid (where the dust collects) you can twist the inner plastic filter about 30 degrees to unlock it. Then, with a bit of "fiddling" with the fold out part (press the unlock button and rotate the suction part as if you were going to use the unit) then, the plastic internal part and the whole suction bit will come off the motor part. Do this slowly as the inner filter will be full of dust and muck. You can then take the filter out, tap it clean in the bin and then wash and dry it with washing up liquid (gently) and allow to fully dry before putting it all back together again.
Nov 28, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Hi i just got a hori screen protector and have already applied it but there are some significant bubbles underneath the screen and with a closer look you can see that there dust inside the bubbles. Is the...
you can wash it with warm soapy water. just rub it gently and rinse. once washed shake it to dry it off. don't let it sit and air dry for you could end up with more dust on them. if you can use a tweezer to hold one corner as you dry it and try not to get your fingerprints on it. these things are like glass magnet once clean and dust free they'll stick back on the screen. once you have it clean and dry try placing it on the screen best you can and squeeze out from the center and press out in all direction. if your placement is wrong replace it before starting to squeeze out
May 11, 2010 | Hori Protector for Nintendo DS Lite
We have a red and green light shining through the screen. You can only notice it when the background is white.
You may need to clean the projection lenses (all 3). They can usually be accessed by removing the rear cover and removing the light deflection plate (it just keeps light from leaking out of the TV into the area behind your TV). Dirty lenses scatter the light and cause dim, washed out images. Clean them with a soft dry cloth to remove the dust, but do not scrub. Once the free dust is removed, lightly moisten a soft cloth with dish water and continue cleaning the lenes. Dry and polish lightly with a soft cloth.
Mar 15, 2010 | Televison & Video
PARTS FOR WASHING MACHINE
Try this link and enter your model number. You may be able to find the part you seek there. Sure hope so and best wishes.
http://www.spares2go.co.uk/browse-PHILCO-m290.htm
Aug 25, 2009 | Washing Machines
My bissell bagless vac has no vaccum. ihave
You will have to clean the filter and clean the main motor.  I had this issue on mine and the main motor was so full of dust bunnies, that it stopped it from creating a vacuum.
Mar 06, 2009 | Vacuums
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
