Question about Garden
How to change string on stihl FE 55 electric trimmer
How to restring
SOURCE: how do i restring the Ariens st 622 string trimmer
Cut two pieces of 18" commercial grade line - one to mount on each side. Look at the series of holes, two on bottom of rotating head, two immediately above but on outer lip of plate. Go up through the bottom two holes, even up your piece of line (like when you are putting in a new shoe string in a pair of shoes) and cross over then out through the top two. All done. If you are using an adequate grade of commercial line you can trim for hours over the roughest of stuff without worrying about restringing.
Posted on May 07, 2009
  • 57 Answers
SOURCE: stihl string trimmer shaft viberation, how do you
Most of these type units only allow you to replace the entire shaft assembly. Have one myself and could not get just gearbox.
Posted on May 19, 2009
nova2nv
  • 197 Answers
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Posted on Nov 28, 2009
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
jyackle5
  • 8197 Answers
SOURCE: Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Posted on Jun 27, 2010
Set the timing on a stihl 55
0.025 feeler gauge or thickness of a business card
Feb 21, 2015 | Stihl String Trimmer Brushcutter Service...
Why does my stihl f45z trimmer stallout?
Fuel, fuel lines, carb adjustment or rebuild carb.
Sep 03, 2014 | Stihl String Trimmer Brushcutter Service...
Stihl repair manuals where can I find them
repair manuals maybe thru a dealer . but it won't be free
Aug 20, 2014 | Stihl String Trimmer Brushcutter Service...
How to change heads on stihl fs 81?
There should be a hole in the gear box for a pin. Insert something in that hole to hold the shaft from turning and unscrew the head. I believe it is reverse thread
Jan 01, 2013 | Stihl String Trimmer Brushcutter Service...
Restring stihl fe55
easy spool head or not??? your owners manual has directions.
Sep 02, 2012 | Stihl Fe 35,40,55 & Ec70 Electric...
What is the fuel line routing on a Stihl FS 44?
Bigger (inner)of the two hoses is the supply to the carby ,the smaller hose (outer) fuel return from carby to tank.
Aug 26, 2012 | Stihl String Trimmer Brushcutter Service...
Stihl four stroke brush cutter wont rev
Check valve clearance. The four stroke engines need regular checks on the valve clearance's
Jun 19, 2012 | Stihl String Trimmer Brushcutter Service...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
