Question about Kenwood 1090VR Receiver
Kenwood 1090VR optical digital settings
Optical digital audio only from Panasonic TC-P50ST50 TV to Kenwood 1090VR. What should the settings on the TV and Receiver be in order to get sound from the home theatre speakers that are connected to receiver.
  • 4234 Answers
SOURCE: Kenwood:1090VR Cracking sound from front speakers
There are poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Look for 3-legged transistors attached to small metal heatsinks, If you can solder, resolder the pins on those parts. Also look for any connections that appear to be grasiny or have rings and resolder them too.
Keep us posted.
Dan
Posted on Feb 06, 2009
smarthome2
  • 1114 Answers
SOURCE: kenwood vr-5900 no sound
Check you settings on the receiver. get into the menu of the unit and check the "Audio" settings. if you can choose by specific input, select "Digital" otherwise, select "Auto" that should correct the problem. If you still have a problem, post a comment and I can help you troubleshoot some more.
Posted on Jul 26, 2009
nokurajesh
  • 101 Answers
SOURCE: No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Posted on Jan 10, 2010
  • 6 Answers
SOURCE: Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
How can attach external speakers with RCA plugs or a mini-plug? Is the digital audio output the only connection for audio output? (The model is TC-P50G25)
Well isn't this just a find how do you do!!
It appears that on this set there is no headset or other audio connection other then the optical?
It appears the only way to a traditional RCA audio jack is via a special adapter. See image. Inexpensive not sure of the quality of audio.
The best way would be to purchase a sourround sound speaker amp system with 5 speakers plus base woofer. These surround sound systems are usually have optical connected and for best results this would be my first choice.
Some have wireless back speakers to allow for easier installation.
RCA RT2781BE 1000W Home Theater System with Bluetooth This unit has two optical inputs and one digital input.
This is an inexpensive surround sound speaker system that should connect to your Panasonic TV optical output. Very available and I wanted to give you at least one option. Wires etc are a mess but the surround sound can be amazing. I would check all the reviews if you decide to go with this type of audio system. They can be confusing and in your case you need to have input control of volume with optical.
The following link is the manual for this particular Home theater System.
http://rcaav.com/wp-content/uploads/2014/11/RT2781BE_IB_0708.pdf
These audio systems can be very expensive. Less expenesive sorround can still provide great listening results.
Hope this helps?
Mar 03, 2016 | Panasonic Tc-p50g20 Viera G20 Series 50"...
How do I get digital audio out from a panasonic panel to optical in on a yamaha amp
The TC-L55E50 has an optical output located on the rear of the TV. Simply connect the optical cable from the TV to the amplifier.
Mar 23, 2014 | Panasonic 55 inch VIERA 1080p 120hz LED TV...
How can I hook a vizio soundbar 2.0 to a Panasonic t.v. Model number tc-p42c1
TV's generally have optical / toslink connections for their digital audio output. I'm assuming the sound bar has a coax digital input, in which case you will need an adapter module. I have seen these on eBay for around $15.
Try searching: Optical Toslink Audio Converter to Digital S/PDIF Coax
Jan 22, 2014 | Panasonic TCP42C1 Plasma TV
Optical port problems
a suggestion, take it back and tell them when you opened the box it was this way--a whole pc board is likely to have to be replaced that has the connection on it.
Dec 23, 2012 | Panasonic VIERA TC-P50ST50 50-Inch 1080p...
I have a panasonic viera Tc-L42D2 Tv and have a amwT342 5.1 home theater system and has it connected using the opitical cable which i was told by panasonic that the only audio connection is the opitical...
Very sorry to inform you that the digital optical socket at the back of your AMW T342 is not digital in but digital out. In other words you can connect the audio output of the AMW to another device like a AV Receiver or a Digital recorder etc and not vis versa. They have not provided a digital input and unfortunately your Panasonic TV only has an optical digital out for audio .
Mar 21, 2011 | Audio Players & Recorders
How to connect a panasonic tcp50gt25 tv audio out (opictal) to a pioneer amp.with opitcal. i connect the cable but no sound,any idea for setting,i did the setting for optical on the amp but still no sound
What is the source? if you are using an HDMI connection from an HD source you should have digital audio. also, if you are connecting digital cable directly to the TV it will send digital audio out as well. check the optical cable at the amp end to see if it is working. it should glow red at the tip if it is.
there are digital input mode settings as well on some receivers. if it is set to DTS it won't work on PCM audio. if it is set to auto Digital it should work on any standard. check the PCM or DTS options in both the TV, and receiver if those settings are there.
Mar 12, 2011 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
HOW TOO CONNECT AUDIO OUT?
hi,
u can connect the digital audio output (optical) to ur av receiver or any amplifier wich have a digital audio input(optica).
ok
Dec 21, 2010 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
I just bought a Panasonic plasma tv model TCP50S2 and I can't seem to get my Kenwood receiver to work with it. Do I need to set the remote to the Panasonic tc? If so does anyon know the code number? I...
I assume you want the TV sound through the receiver?
You need to connect the TV digital out to the receivers digtal in.
This is probably an optical connection.
Then you need to switch the receiver to the correct input. You may also need to tell the receiver what kind of connection is made: Optical or coaxial, if it doesn't detect this automaticly.
Sep 22, 2010 | Kenwood VR-705 Receiver
Mar 23, 2009 | Kenwood VR-405 Receiver
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
