What size hard drives can i use in a acer ase380-ud421a
I would like to know what quantity and size had drives I can install in an acer ase380-ud421a
    Problem Solver:
  • 8 Answers
This information should be fairly easy to find in your user's manual. If you don't have one, go to the manufacturers website and search for one there. Almost all manufacturers make these available online. Good luck!
Posted on Apr 20, 2014
3 Suggested Answers
  • 33 Answers
SOURCE: cannot not add second hard
You may have the jumpers on the hard drive wrone.
Either it has to be your primary hard drive set for master and the second one set for slave or both set for cable select.
You may also have to go into the bios and turn on the secondary hard drive capability.
Posted on Jun 01, 2008
  • 79 Answers
SOURCE: aspire ase380-ud421a
Try going to system setup by hitting Delete when you see the acer/aspire logo when you restart, then open your drive there. If it doesn't work, it is likely that your drive needs to be replaced. You could also try reseating (pulling out and putting back in) the cables inside the computer that's connected to your drive. All else fails, replace the drive.
Posted on Dec 19, 2009
What kind of cpu cooling fan can I use in a Acer America ASE380-UD420A desktop computer?
Cooling fan to CPU are come along with the CPU. You can use any other fan, having speed regulator pin, ie, the connector wire to it will have three conductors. Keep a close look at the size and seating screws to its body to the heat-sink of the CPU.
Jul 22, 2014 | Averatec Sotec 3200 Series Fan with...
What is the case fan size for a acer aspire ase380-ud440a desktop computer? Also what size is the CPU fan?
no need to replace just remove the label sticker from the fan and remove the smaller lock from the fan shaft be care full its very typical to remove that lock just use 2 needle with one needle press and hold the lock with other lift up lock from the cut side lift up the lock and remove the fan from bushing just clean both bushing and fan shaft with any rust remover cleaner clean well after clean both just apply any kind of lubrication oil and re assemble the fan it will be free of noise.
Jul 14, 2014 | Acer Computers & Internet
How do I find the Acer Aspire ASE 380 UD421A schematic?
Computers are wired like a car. Your "wiring harness" comes with plug ins for upgrades, like a second hard drive. In all likely hood if the computer is running correctly, these plugins are for upgrading purposes.
Jun 09, 2014 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
I cannot get my acer aspire e380 ase380-ud500a desktop cd door open. i do not see a little hole anywhere
It may be hard to see, but there is a very small hole in the CD drive that is almost the exact size of the end of a paper clip. Gently push that paper clip wire into the hole. You will meet some resistance and the drive will open.
Aug 24, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
I'm trying to re-intall windows xp from CD on an Acer Aspire 3680 but the screen shows a disabled "Install Windows XP" choice. Could you explain why and how to get around it?
Be sure your laptop is set to boot to the cd drive. You'll have to press a key to boot to cd, when prompted to do so. I always delete all the partitions, if I want a good, clean install. Then I would create a partition. The size and quantity of partitions depends on the size of your hard drive. If you have a 160GB drive or larger, I would create at least one partition that was 50GB in size and use it for the XP(install) partition. This will help with system performance and stability. Be sure to use the complete format and not the "Quick Format".
Hope this helps you.
Jan 20, 2010 | Acer Aspire 3680 Laptop
Aspire ase380-ud421a cd/dvd drive stopped working
Dec 19, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
My acer aspire ase380 emits a short buzzing sound periodically. it sounds more like a speaker buzz and not really my hard drive , does anyone know what it may be? (Hi-temp warning?possibly?)
Could it possibly be a wire rubbing off a fan inside? ive experienced that before. Does the sound start as soon as you turn on the computer or after a while?
Jul 29, 2009 | Acer Computers & Internet
Cannot not add second hard drive to acer ase380-ud421a desktop
Jun 01, 2008 | Acer Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
