Question about HP Computers & Internet
Unlock dead vingcard lock
When programing a door.the iPAQ gives a facility error code.
huuum
  • 750 Answers
SOURCE: F09 Error
This is what F09 means
Condition
Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Check and repair
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check for Drain Pump Failure
  • Check the Inlet Valve for proper shut off
  • Check the Pressure switch for proper operation
Posted on Dec 05, 2008
SOURCE: Error Code OE and Door will not unlock
error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.try running the spin cycle alone till the water empties completely.If the problem still continues it means that the pump is clogged where you cant reach, since you've tested with the drain hose.
Posted on Dec 16, 2008
jyackle5
  • 8197 Answers
SOURCE: oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
  • 8 Answers
SOURCE: front load washer. Door will not unlock get error
Sturdy little door, isn't it? Make sure you don't have extra water in the machine, as this will cause the door to not unlock. With that done,unplug your washer. If you can get the top of the machine off and reach down the front of the washer, you should see the latch mechanism. Push this down. Door should unlock. Now. Buy a new latch assemby.
Posted on Mar 28, 2010
sisadsl
  • 1508 Answers
SOURCE: how do you unlock door when jeep battery is dead with keypad lock
Not sure about jeep, but some you can pull a tail light lens out, pull a bulb out, break up an old bulb and solder two wires, put modified bulb base back in and back feed the power circuit
Posted on Apr 04, 2010
Testimonial: "Thanks a lot - please check my comment for more info for everybody to see"
Sim unlock HP iPAQ Data Messenger Smartphone
hi you can use codes to unlock your hp ipaq data messenger.you can get the codes from this site simpleunlocking here they ask the country and the network name to which your mobile is locked .finally they will send you the codes to unlock your mobile along with the instruction about how to use the codes in your mobile.
Nov 17, 2011 | HP iPAQ Data Messenger Smartphone
How to unlock hp ipaq hw6920?
The HP IPAQ HW6920 locked in which Country's Network ?
You can Unlock it using the Unlock code from the website
Superunlockcodes there you can get the Unlock code at low cost and unlock it,check code for your network lock,Country!!!!
HP IPAQ HW6920 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HP IPAQ HW6920 mobile phones. If you enter over a certain amount of wrong unlock codes on your HP IPAQ HW6920 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON the HP IPAQ HW6920 with a sim card that is Not accepted.
2 - The HP IPAQ HW6920 will prompt you for an unlock code.
3 - Enter the unlock code, which you can buy from our website.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your HP IPAQ HW6920 is locked to.
Each HP IPAQ HW6920 mobile phone has an unique unlock code. You can buy the unique unlock code for your HP IPAQ HW6920 mobile phone using the form above.
May 25, 2011 | HP iPAQ hw6920
Cannot find my manual and would like to know how to use the self-cleaning part. I held the button down for "lock", but the door did not lock, and where do I go from there?
Give this a try:
1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds. Momentarily (less than 5 sec.) press CANCEL key again to remove error code display. 2. Program and start the Clean mode. Observe to see if door locks. If it does not, inspect the locking mechanism from the solenoid to the latch pawl and door to find the cause of the problem. If the door is not locking, then 1 minute from the start of the Clean, the F5 E1 code will again be displayed. Press CANCEL key to remove error code display. 3. Once any mechanical problems with the latch mechanism have been corrected, program and start a Clean cycle (after, if necessary, clearing F5 E1 error code) to ensure proper operation of the door lock. Immediately cancel the Clean mode to observe proper operation of door unlock.
If this doesn't help try this link to locate the right model:
http://www.whirlpool.com/catalog/category.jsp?categoryId=76
Feb 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
THE BATTERIES WERE DEAD IN REMOTE FOR KEYLESS-ENTRY
This works on the older troopers min is a 95 giv it try
A-Open the driver’s door.
B-Insert key into ignition.
C-Turn the ignition switch to the ACC position and then to the LOCK position three times. (This step must be completed within 3 seconds – go as fast as you can, or the system will not enter the programming mode.)
D- Within 10 seconds, close and open the door two times.
E-Turn the ignition switch to the ACC position and then to the LOCK position three times (again, do this within 3 seconds.)
F-Within 10 seconds, close and open the door. Verify that the power door locks cycle once to confirm that the system is in programming mode.
G-Within 20 seconds, press the LOCK button on the transmitter you are programming. Verify that the door locks cycle once.
H-Within 20 seconds, press the UNLOCK button on the transmitter. Verify that the door locks cycle once to confirm that the system has accepted the transmitter’s code.
I-Repeat steps 7 and 8 for each transmitter to be added. Remove key from ignition.
Oct 16, 2009 | 2001 Isuzu Trooper
Keyless remote wont work
try to reprogram the remotes using these instructions..........
i assume for 02 explorer not th 05 frestyle listed (although similar procedure)
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Make sure that the anti-theft system is not armed or triggered and key code programming is not active.
  1. Open the door, then press the driver door lock control switch UNLOCK button.
  1. Turn the key from OFF to ON 8 times within 10 seconds, with the eighth turn ending in ON. If the program mode is sucessfully entered the doors will lock and unlock to confirm.
  1. Press any button on a remote transmitter, and the doors will lock and then unlock all doors to confirm that the remote transmitter is programmed. All remote transmitters must be programmed within 20 seconds of each other. Up to four remote transmitters can be programmed to the vehicles security module each time programming mode is entered.
  1. If the door locks do not respond for any remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Locks, Latches and Entry Systems — Late Build or Locks, Latches and Entry Systems — Early Build in this section.
  1. NOTE: Exiting is acknowledged by locking and unlocking the doors if at least one remote transmitter has been programmed.
    Exiting the programming mode is accomplished if one of the following has occurred:
    • The key transitions to OFF.
    • 20 seconds have passed since entering programming mode or since the last remote transmitter was programmed.
    • Four remote transmitters have been programmed.
Jun 02, 2009 | 2005 Ford Freestyle
Ipaq H3630 how to do a hard reset
Compaq iPAQ h3630
Resetthe iPAQ H3000 and Clear Memory
Resetting the iPAQ
Ifyour iPAQ H3000 responds slowly, stops responding as expected, or“freezes,” try resetting it. A reset causes the iPAQ H3000 to restartand re-adjust memory allocation. Unsaved data in open windows may belost. Use the stylus to press and hold the Reset button for about twoseconds.
NOTE:Do not turn off your iPAQ as it must remain on in order to reset.
Clearing memory
Ifyou want to clear all data from your iPAQ H3000 and return it to thefactory settings, you should clear the memory.
Clearingmemory deletes all data and restores the iPAQ H3000 to its defaultsettings. Programs installed at the factory remain, while data you havecreated and programs you have installed are erased.
1.Using the stylus, slide open the On/Off door on the base of the iPAQH3000.
2.Slide the On /Off switch to the Off position using the stylus. Waitabout one minute, then slide the switch to the On position.
3. Close the Battery On/Off doorusing the stylus.
NOTE
:Use CF Backup/Restore or ActiveSync to keep a backup of your iPAQ dataso that if you need to clear memory, you can restore the data on youriPAQ.
http://www.hardreset.eu/compaq_ipaq_h3630_hard_reset_soft_reset_en.html
Aug 29, 2008 | Compaq iPAQ H3630 Pocket PC
IPAQ 6965 problem
Go to \Windows\StartUp and delete the offensive program.
May 13, 2008 | HP iPAQ hw6965 Smartphone
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
Computers & Internet Logo
75 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
