Question about GE 7.0 cu. ft. Electric Dryer - DCVH680EJBB
Dcvh680ejbb does not spin, makes buzzing sound
My Dcvh680ejbb GE electric dryer does not spin any longer, when I push start it makes a buzzing sound continuously.
kevin000
  • 1847 Answers
SOURCE: the start button on the
i feel it is loose connection issue,
Posted on Jun 08, 2008
  • 1122 Answers
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Posted on Mar 21, 2009
  • 384 Answers
SOURCE: ge dryer dvl223ebww hear buzzing sound when trying
motor capacitor bad
Posted on May 06, 2009
hunter19_46m
  • 7482 Answers
SOURCE: our ge profile electric dryer has recently started
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Posted on Oct 15, 2009
heatman101
  • 43501 Answers
SOURCE: GE DPSR483EA Electric Dryer was making a scraping
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 15, 2010
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
When I press the start button on my GE DPSR610EG4WT profile dryer it only makes an electrical buzzing sound and will not turn on or start. What causes this?
The buzz is probably coming from the control switch drive motor. If it is not turning the switch, the dryer wont run.
murf427
Aug 02, 2012 | GE DPSR610EGWT Electric Dryer
The dryer makes an electrical buzzing sound but the drum doesn't spin. I can spin the drum manually, which I never could before the problem started. Model GE DBVH512EFOWW
michael00256 (that's a great name by the way). several things could be going on. If you can gain access inside the cabinet, you'll need to do that.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/take-apart-GEelectricgasdryer.html here's some video help that should tell you what you need to know.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/GE-HP-dryer-is-not-tumbling.html here is also a link that should tell you exactly what you need to check.
The problem could be in the motor, with the belt, or a few more things.
If you get this far and still have not solve your problem, please contact me. My name is Mike, and I would be more than happy to help you out in solving this problem.
thanks,
mike
PS; if you're even slightly handy, this could be something that you can do yourself.
Jul 19, 2011 | GE DBVH512EFWW Dryer
Just makes a buzzing sound when you turn the start button on.
that is the motor!try this,open the door,with one hand push in the door switch button and hold it in,as you hold in the button spin the drum with your other hand and have someone else push the start button and see if it starts,if it does you have a bad motor,if the drum doesn't spin by hand you could have something stuck in the blower wheel,let me know what you find
Feb 05, 2011 | Frigidaire FEQ1442ES Electric Dryer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
Dryer has power, just buzzes, does not start to spin
sounds like you need a new motor .or PAY professional help .
Jan 28, 2018 | GE DPSB613GDWW Gas Dryer
Dryer wont start
open door and spin drum to left then right.
Oct 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
DE Dryer #DBSR453
if the dryer is humming when you are trying to start it it has a motor problem replace the motor
Jun 17, 2008 | GE DBXR463EBWW Electric Dryer
GE 7.0 cu. ft. Electric Dryer - DCVH680EJBB Logo
15 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
