Question about Graco Infant SafeSeat (Step 1) 8A05RXY in Roxy
Put seat cover back - Graco Infant SafeSeat (Step 1) 8A05RXY in Roxy
  • Graco Master
  • 1,629 Answers
Hi Casey
We would recommend you contact Graco direct for assistance
Posted on Jun 22, 2014
Need to put car seat cover back together
Hi
Which country are you in / which model Safety 1st carseat do you have?
Dec 05, 2011 | Safety 1st Baby Gear
Am looking for installation instructions for installing the Pro Pad motorcycle gel seat insert into an existing seat.
there is nothing like a gel seat. this is easy as long as your not in a hurry. start by removeing the seat cover a small flat head and needle nose will help. after you have it off there is one of two ways to get this done. first set your gel and trace the outlineon youseat foam. with a razor blade cut the seat down to the depth you need, now like a slowly start to pull the foam up and cut under it as you pull it up. i like to let the gel sit so it has about a mm above the foam. after you have the gel so it sits nicely in the pocket you cut out use car headliner to cover the top of the seat some 3m spray glue will keep it from moveing around. the head liner is so when you put the seat cover back on it will not show the lines where the gel is at. put your seat cover back on and start on the sides of the seat 1
#2 and #3 put a staples in 2 3
there start ontoward 4
the front of the seatpulling the cover tight as you staple it down. after you have the front down work the same way to the back.
Good luck
Mark
C.C. Motorsports
Feb 22, 2010 | 2005 kawasaki VN 800 Vulcan Classic
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Need to put car seat cove back on
This can be very tricky! Usually, you must put on the cover first, then guide the belt through the openings from the front. Turn the metal retainer clips sideways, and then anchor them on the back of the seat. I used to have one of these seats, sorry I do not still have the manual though. You can also try going to the company website for advice. Good luck.
May 20, 2009 | Safety 1st Vantage Point 22-560
I am trying to put seat covers on my back seats in my 1992 lexus
place a crowbar under the seats near the carpet and, pry up gently the car has clips under both sides of the center seats then: push down on the top of the seat back disengaging it
Apr 22, 2009 | 1992 Lexus Ls 400
Seat Cover in Pontiac Montana
Not sure about the storage bins BUT,if you have side airbags in the seats make sure the seat covers are "side airbag" compatible.
Jun 01, 2017 | 2005 Pontiac Montana
Instructions on how to instal a second hand safe-n-sound car seat
how do i put the straps back on through the cover
Oct 19, 2008 | Baby Gear
Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Sep 03, 2008 | Britax Eclipse Si - Paris Convertible Car...
Car seat cover
You should definitely check your owners manual. Different seats require different things to be removed (like the harness). If you can't find yours, you should be able to find one online by searching Google.
Jun 08, 2008 | Baby Gear
Graco Infant SafeSeat (Step 1) 8A05RXY in Roxy Logo
64 people viewed this question
Top Graco Baby Gear Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
