Question about Equity Time USA 30731 LED Digital Electric Alarm Clock
Replaced batt can not power on
4 batteries
    New Friend:
  • 3 Answers
The connection from the battery to the circuits are failing, return and get a replacement or new alrm clock
Posted on Apr 20, 2014
My bike will not run on batt power only charge already replaced batt
Needs statter replaced or regaltor replaced charge battery start bike put a voltmeter on battery to see how many volts is charging shouid be 13,50 try that MOPAR KENNY
May 22, 2011 | Suzuki GSX 600 F (Katana Motorcycles
M863 on turning on immediately closes down. Battery replaced and fully recharged-still problems persists.
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 21, 2009 | Kodak EasyShare C613 Digital Camera
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Ready light keeps flashing red. Replaced with a new battery from Kodak today but did not fix problem. No picture in LCD.
If the correct recommended batt supplied from KODAK didn't solve the problem Then a repair is recommended.
Info on batt:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Oct 30, 2009 | Kodak EasyShare LS443 Digital Camera
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
Slides not working nor the power jack
Did you wire them in circuit? (hot lead to positive on 1st batt, which jumps to the neg on 2nd batt, and neg lead going to neg post on 1st batt, then to positive on 2nd batt) That would be for a 24v system, for a 36v you would continue to the opposite posts again.
Jun 02, 2009 | Ryobi Multi-Volt Battery Charger
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Honeywell Chronotherm III is stuck on Repl Batt
when i have seen this in the past, i have been able to clean the contacts that the batteries touch.they may not look dirty, but if they get a little corrosion or get tarnished, they will not let the full battery power get to the stat and it will think the battery is low. try cleaning it with some emery cloth and see if that helps.
Jan 12, 2009 | Honeywell Power Humidifier: Furnace...
Restarting
If CONTROL-ALT-DELETE is not bringing up the task manager options, either hold down the power button or unplug the battery and power supply.
Good luck...
Nov 21, 2007 | Acer Aspire 3000 Notebook
Equity Time USA 30731 LED Digital Electric Alarm Clock Logo
Top Equity Time USA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Equity Time USA Audio Player and Recorder Expert? Answer questions, earn points and help others
