Question about Epson TM-U220 Matrix Printer
What is the IP Address for Epson TM- U220PD
  • Jith Nov 28, 2013
    Use the utility TM net winconfi 3.0 and serch your printer current IP and this utility helps u can change the IP address .(Password is blank)
If you have the same model, on the back of the printer next to the ethernet port is a little button/ hole. Push and hold that down for a couple seconds until it starts printing. It will print out the IP address. Manually assign your computer to have an IP address in the same range (I.E. if the printer says 192.168.1.23, set your computer to 192.168.1.29 with the same subnet mask, etc.). Plug a network cable from your computer directly into the printer. Then, you can change the settings.
Posted on Mar 04, 2010
    Scholar:
  • 31 Answers
The best way to connect to this printer is to plug the network cable from the printer into a PC, set your PC to Static IP 192.168.192.100 Subnet 255.255.255.0
Save your settings, and than open internet explorer, or firefox, and access the printer by going to 192.168.192.168
This will allow you to change the settings to your current subnet, and save.
Hope this helps.
Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Posted on Jun 30, 2009
Switch on your printer while pressing feed button.printer will print some and u can read ip address of printer in printed page.
Posted on Oct 28, 2010
    Genius:
  • 1,018 Answers
I don't understand your question.
The IP address is normally set by the Vendor and hardcoded into the device.
Normally you can find it on the manufacturer's label. That is providing the the device is supposed to be sharable across the network.
If the device was only intended to be shared locally, then you would connect it to the PC and share the device via the PC.
Don
Posted on Jun 19, 2009
  • a_jeram Oct 28, 2010
    switch on your printer while pressing feed button.printer will print some and u can read ip address of printer in printed page.
  • Jith Nov 28, 2013
    Simple Logic u can Use TM net winconfig utility and serch and configure the IP address.
I need a printer driver for Epson TM-U220PD receipt printer for XP
http://www.posmicro.com/RECPRINTERS/EPSON/EPSON%20DRIVERS.htm here you go if it works let me know via a message or thumbs up if not i will continue to help you
Mar 16, 2011 | Epson TM-U220PD Matrix Printer
Trying to install epson tm u220pd with USB port, what drivers do I need? Plug and play does not install it in setup wizard
if your using TM-U220PD which is a parallel , you should connect it in parallel port then use this printer driver http://pos.epson.com/developers/techresdetails.htm?productpk=545
Feb 18, 2011 | Epson TM-U220 Matrix Printer
Where I can find driver of printer Epson TM U220PD for Windows7 ? ? ?
If there are any you'll get them here
https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?url_jsp=http://www.epson-pos.com/
Aug 19, 2010 | Epson TM-U220PD Matrix Printer
To install Epson printer TM-U220PD Model M188D
What is the baud rate of the EPSON TM-U220D MODEL M188D?
Feb 14, 2010 | Epson TM U220D Printer
Error LED keeps flashing
your printer needs to be serviced
http://pos.epson.com/service/servASPP.htm
look for a service provider on this website
Feb 20, 2008 | Epson TM-U220PD Matrix Printer
Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
Jul 29, 2007 | Epson TM-U220PD Matrix Printer
Epson TM-U220 Matrix Printer Logo
12,586 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
