Question about Atec Power Hummer Baseball Pitching Machine
I have an Atec power hummer pitching machine but can't get it to turn on
Melting wheels on Casey pitching machine
First thing is to be sure the wheels are oem. Second would be to attempt to shade it or paint the rims on the wheel silver to reflect the heat. If is most likely the glue used on the rims is a heat set adhesive and melts at about 140 F
Jun 19, 2016 | Cars & Trucks
I have 4 atec casey2 pitching machines with blown motors
Look for a motor rewinding/repair service. Sometimes it's cheaper that a new motor.
Sep 25, 2014 | Cars & Trucks
Power shuts off when i turn on switch
There can be two possible reasons for this to occur. The first would be that the pitching machine might need more power than that which is available at home, or the machine might be working for a long time and may have got heated up.
Jun 19, 2014 | Jugs Small Ball Pitching Machine
How can i fix the wheel on a atec casey pro pitching machine because they tend to melt with the sunlight?? anybody got the same problem pleaseee...
I had one to melted off today ,while I had in my truck they need to make a sign and put on them the wheels are 500.00 just don't do it again
Apr 09, 2013 | Cars & Trucks
Where do i find a replacement wheel for a atec casey 2 pitching machine
This is posted in wrong area--try posting in sporting goods or an area related to the item.
Jun 06, 2012 | Televison & Video
NEED WIRING DIAGRAM
need wire diagram, what are you working on.
Dec 13, 2011 | Sport & Outdoor - Others
How to remove the wheels on a Casey Pro? Do you just use a wrench and twist extremely ******* the lug nuts or is there anything else you need to do first?
I have the same problem with trying to remove a Casey Pro pitching machine wheel. The main problem I am having is trying to stabilize the wheel so it doesn't spin so I can really try to exert enough force to remove the lug nut. Any ideas anyone???Thank you.John
Aug 16, 2011 | Atec Casey Pro Baseball Pitching Machine
Atec Power Hummer Baseball Pitching Machine Logo
173 people viewed this question
Top Atec Baseball & Softball Experts
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you an Atec Baseball and Softball Expert? Answer questions, earn points and help others
