Question about Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Whining noise and no pumping
Pump whines and does not move water or is not pumping at all. Impeller is free from obstruction
    Top Expert:
  • Hayward Master
  • 5,080 Answers
Replace whole unit less hassle
Posted on Jun 15, 2016
  • 11 Answers
SOURCE: I lost water pressure in my swimming pool line and
If your pump is blocked in any way (usually a closed valve), then the pump cannot keep water flowing. It could be starved of water if blocked on the suction side, or an air leak. On the return side, it's usually a ``dead head`` pipe, or a closed outlet valve. In either case, the pump can overheat and actually boil the water within it. In that case, the fittings attached to it can deform and cause bigger air leaks, which compounds the problem. If you replace the fittings, reconnect the pipe and remove any blockages, you should be fine.
Posted on Aug 03, 2009
  • 64 Answers
SOURCE: Start pool up this year pump is louder makng whine
loud screaching noise??? sounds like bearing failure. this most common failure of pool motors. YOu can try to replace the bearings or replace the motor.
Posted on May 22, 2010
SOURCE: water coming out down by motor
sounds like a shaft seal leak..... cut power to pump ... unbolt the motor at the seal plate and pull motor from pump... take electrical cover off back of pump and hold the shaft at the middle (may have to do some digging to find it) of the back of the pump... now youll be able to remove the impeller by spinning it counter clockwise...
make sure you dont go cheap on the seals... and make certain to replace all seals on pump
(diffuser oring, housing gasket, shaft seals, and lid gasket
Posted on May 24, 2010
MOTORWIZJ
  • 1340 Answers
SOURCE: how to disassemble impeller on rs1000 hayward pump
OFF TO THE LEFT FOR REMOVAL OF A IMPELLER BUT SOME MAY HAVE A SCREW IN THE CENTER IT IS A LEFT HAND THREAD SO IT OFF TO THE RIGHT.. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY TO HAVE IT DONE RIGHT
Posted on Jun 29, 2010
  • 366 Answers
SOURCE: I have Hayward Centurian SE 2 hp pool motor
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Posted on Jul 04, 2010
Whining noise while engine is revving/accelerating
check power steering pump fluid, with engine off try to wiggle every pulley if any move at all that's your culprit, power steering, alternator, idler puller, water pump, but sounds like bearing failure
Jun 08, 2012 | 2006 Hyundai Getz 1.4
Pump is whining and making very loud noise.
Install air vent?
Clean pump impeller with white vinegar?
replace pump?
Troubleshoot resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Gene
Dec 27, 2010 | Grundfos Comfort System Recirculator ...
I have a DREAMMAKER SPA (6 months old) with a 2 speed HYBRID PUMP. It has developed a high pitched whistle or whine when running. Is this a bearing? Could there be some stuff stuck in the impeller??
90% chance it is indeed the bearings. It is possible something could be stuck in the impeller causing noise, but not usually a high pitched whine. If you see water leaking, or calcium buildup where the pump meets the motor, then the shaft seal has failed and that is what's causing the bearing failure. Either way you'll need to replace the motor or have the bearings replaced. Look for a local pool pump repair shop (or some pool supply stores replace bearings as well). They should check the motor out for free and give you estimate to to repair/rebuild, or a price on a new motor if that's what you need/want. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 11, 2010 | Dream Maker Spas Dream Maker SpaDition...
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
My pump whines very loud while running? Any
check the motor bearings,(take the pump apart from the motoer should 4 bolt,,,, then wiggle the shaft should not move at all.) then look at the impeller to see how worn it is or if it is touching any part of the houseing.
Jun 29, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
NOISY WHEN DRAINING ON OCCASION
This is a sign of a faulty drain pump impeller. the drive shaft that is connected to the impeller is stripping the impeller. you will eventually need to replace the entire pump soon.
Jun 06, 2009 | Fisher Paykel Eco IWL16
Whining noise after water pump installation
If it's a 2.2 there is a special tool that holds chain while servicing the H2O pump.If you didn't have it the chain slipped & is now too tight causing the whine.You will need to take everthing apart.I woulr recommend replacing the chain & all guides(kit) Hope this helps
May 23, 2009 | 2001 Saturn L-Series
Kenmore washer makes a whining noise
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer makes a whining noise while pumping water
This is caused by the pump. Replace or clean out the pump.
Whining noise from engine
Hello
altho new you may have a whining water pump or tensioner or it may be over tensioned.
take a long screw driver & place in on the timing cover to try to here where the noise is coming from, this should help you find the proplem with the car
Regards Paul
www.limotec.co.uk
Jan 11, 2009 | 2000 Volvo V40
Hayward Power Flo Lx 1 Hp Pool Pump Sp1580 Logo
67 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
