Question about HP Pavillion s7420n PC Desktop
Spooler on computer /printer is not running
Printer will not print from pc. message is "spooler is not running"
    Problem Solver:
  • 6 Answers
1. Click on the Start Button
2.In the Search Box type: services
3. Click on "Services" from the search results-The one with the little gear icon before it
4. In "Services" double click on "Print Spooler" and click Start
5. Startup type: click automatic and then click Apply on the bottom
Posted on Apr 20, 2014
3 Suggested Answers
JongCur
  • 88 Answers
SOURCE: Printing Error
Try this:
1. Power off the printer
2. After re-boot: click start, control panel, printers & faxes and delete the printer.
3. Re-install the printer with the original driver disc.
There are many suggested solutions to spool problems but try this first. If this does not work we'll go to the other solutions.
Posted on Mar 31, 2008
  • 10 Answers
SOURCE: How do i get my print spooler up and running
I advice you to stop it first then install the printer and then start once its done.
Restart the spooler by doing the following:
a. Click Start > Run, and on the entry field, type in "net stop spooler".
b. Hit Ok.
c. Click Start > Run, and on the entry field, type in "net start spooler".
d. Hit Ok.
You can pm me for remote assistance for free.
Thanks.
Posted on Sep 11, 2009
When printing from the PC my PC says "the print spooler service is not running"the PC i'm using was communicating with the admin PC. is it possible for me to connect to the printer trough the offi
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
You can also try this WEB site
MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Apr 02, 2013 | Office Equipment & Supplies
Where i could see the printer spooler?
I open the run command you can type: net start spooler
(You will get a message that says the print spooler service has started)
If you still have issues open the run command and type: services.msc
it will display a list, where you can find print spooler.
From there you can right-click on it and set it so it is started and runs automatically.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 25, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
Jan 11, 2013 | Office Equipment & Supplies
I still cannot print
Reboot the computer if the printer is local. Or, type services.msc in run / search. Scroll down to Print Spooler and start by right clicking. You have a bigger problem if this fails to start. Like you may not be an Administrator.
Starting the Print Spooler on a networked printer (at work) is the same, only it must be done by an IT admin on the Print Server.
Dec 10, 2012 | Computers & Internet
My lexmark 2760 is about 1 year old and not used a great deal. It does not print but appears to hold the print instructions in its memory and then decides to print all on its own after not working for...
It could be the print spooler service on your computer. Make sure the service is enabled.
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
Reboot your pc. Unplug and replug the printer into the power outlet in the wall. This will reset your system. Once your printer and the pc's back on, try to print again.
Jun 08, 2011 | Lexmark X2670 All-In-One Printer
Message on PC screen tells me "printer is busy"
Make sure there are no print jobs stuck in the queue. If you're using Windows, go to the Control Panel > Printers > double-click on the Lexmark print object. Delete all print jobs pending. If you can't clear all print jobs, follow the steps below:
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Reboot your computer. Then, try to scan again.
May 25, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Sharing my computers and my printer on ahome network
At first you need to share the printer. in another computer now you can add printer.
Jan 25, 2009 | Acer Aspireā„¢ T180 PC Desktop
Print spooler for Lexmark X74- X75 all-in-one-center
Hold down the power button on the PC for about 3-5 seconds to shut down the PC. Now boot up again and try reconnecting the printer to sse if the issue is resolved.
Jul 04, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
HP Pavillion s7420n  PC Desktop Logo
35 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
