Question about Kenmore Dishwashers
Noisy pump when we run the dishwasher - Kenmore Dishwashers
    Problem Solver:
  • 6 Answers
Recently had a similar experience. Sounded like grinding noise for a period of time. Then motor stopped. Motor bearings were shot. Had motor replaced under P.S.E.&G. Service contract. This utility company offers appliance contracts for the home. P.S. serviceman indicated they will only do that once for the contract. This is an expensive part. If you don't have access to a contract be ready for 130.00 or more for a new Motor and more to have it installed if you are not handy. Service man removed front kick plate and dropped motor without removing dishwasher.
Posted on May 29, 2014
  • Al Seaver
    Al Seaver Jun 09, 2014
    It's also entirely possible that a piece of debris got down into the pump and that the macerator or pump impeller is hitting it as it spins. Disassembly and inspection is you best option.
Not draining completely out and is noisy when running
You might have some hard debris (glass, hard plastic, something else) down in the sump and pump areas. The pump will have to be disassembled to find and fix it. If you're not a handyman, then you probably should call a professional dishwasher repairman.
Sep 24, 2014 | Kenmore Dishwasher With Ultra Wash And...
Bosch dishwasher makes noise while draining
If your model has a separate drain pump? You may have something caught in the pumps impellers.
Dec 04, 2013 | Bosch Dishwashers
Dishwasher very noisy as it goes through it cycle. think its the water pump? sounds like bearings or impeller rubbing off the housing? not as noisy when the machine is cycling empty?
Could be bearings or something caught inside the impellar. If you take the wash arms off and run a cycle with water, it will "sometimes" blow out anything in the impellar. Undercounter machines are usually problematic - recommend avoiding them when possible.
Apr 22, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
My dishwasher is not draining off the water properly. It has flooded the kitchen once already. I can here the pump running, but it is a bit noisy. The bottom of the dishwasher is still full of water after...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Frigidaire Professional Series 24 in....
Has become very noisy during sensing cycle.
Either the motor is failing to pump water or there is too much soap in the system. Add 1/4 cup veg oil and run again.
Sep 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
NOISY DISHWASHER WHIRLPOOL GU3600
If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Jul 24, 2009 | Whirlpool GU3600XTS Dishwasher
Very noisy pump
Ya, almost certainly you need to replace the motor/pump assembly.
Here is an example of a place to source it:
http://www.partadvantage.com/store/showpart/11212384
Good Luck!
May 02, 2009 | KitchenAid 24 in. KUDK02CRBS Stainless...
Noisy cycle and dirty dishes
Hi
Please accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 25, 2009 | Kenmore 24 in. 17362 / 17364 / 17369...
Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwashers Logo
98 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
