Question about HP LaserJet 2100 Printer
Roller marks on paper
Copier/printer makes mark on paper when it picks it up from the tray.
  • Buddy Mcsparrin May 11, 2010
    Where is the mark located on the printed page?
    President:
  • 1,185 Answers
Seperate the paper before you load it
Lay the paper down on a flat area ,take the paper and grip it on both edges half way down the sheets
Bring your hands together to form a bow in the centre of the paper, tighten your grip on the paper at that point straighten your hands out
The paper should be hanging down in the centre with an air space between each sheet
That way it floats off the stack rather than being pulled hard
Also do not over fill the cassette or feeder tray
Wash the paper feed rollers witha bit of Gin or Vodka (It cleans and evaporates quite quickly)
Posted on Jun 19, 2009
No paper error, printer will not pick up paper out of tray, with no luck.
push the side door that face exactly the drawer of the located paper if there any lose ?
if yes you need to put adhesive one side sticker behind the drawer and in the middle to re gain the required pressure on the paper.
Feb 23, 2016 | Office Equipment & Supplies
Flashing question mark
Flashing Question mark is attention light/ paper tray set wrong or paper jam either in user or under toner or in front right after pickup roller or cover open switch is on making contact or toner switch
check roller for wear my not be picking up paper last paper tray gets stuck in left side front check it
Apr 03, 2014 | HEWLETT-PACKARD Office Equipment &...
Erro paper jam 02
Open and Check if there is any paper hiden inside the machine. if not check the paper tray to check if there is any mark of the roller in the paper top edge than clean the paper pick up roller and separation pad( this parts make contact at the top ege of the paper. Use alcohol isopropilic or soap and warm water to clean it.
Oct 23, 2012 | Kodak 6800 Thermal Photo Printer
I keep getting an error message. It will print one page and then the error light comes on and I cannot find anything wrong with it.
its possible the feed rollers that pull the paper into the copier from the tray isn't picking up... you will see marks on the page where it tried to pull it up... if this is so... or its possible that one of the sensor arms that the paper flips... gets jammed and needs to be reset or a sensor along the paper path is bad... I would start with the paper feed rollers
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Mar 11, 2010 | Konica Minolta magicolor 2400 Laser...
My printer keeps telling me to remove jammed paper, but there is no paper in it!! Help, and thanks!
OK do one thing off the printer then restart it.Reset the printer from printer option botton. then off again. After that when you on the printer then the massage naver come.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
It is not grasping the paper.
Get some nail polish remover, the cheapest type that contains acetone. Avoid any "moisturising", "nourishing" or other heavily modified ones. If you have acetone, you can mix it 1:1 with alcohol (isopropyl/IPA ideally).
Now pull out the paper tray and look under the printer. You will see a large rubber roller, usually grey, that picks up the paper and slides it out of the tray. Using a soft, lint-free cloth or paper towel dampened with few drops of the liquid described above, wipe this roller several times, trying to turn it around (with the printer turned off) so that you wipe the whole roller surface. If you cannot move the roller, run the printer once or twice and clean the roller again - it should stop in a different position each time. Acetone evaporates quickly, so add a drop or two between wipes.
Also make sure to clean the separator - it's a rectangular piece of rubber on the paper tray - it has to have enough friction to keep the printer from taking up 2 or more sheets at once.
Be cautious not to spill acetone on your printer or any plastic objects - it will leave unsightly marks, as it dissolves most plastics.
Good luck :) Abd come back with a testimonial if helped :)
Dec 23, 2009 | OKI B2200n Led Printer
Feeds ok from tray 1 but not tray 2 which is 11x17. There are slight buffed marks at on the papaer in 4 spots but paper wont advance. marks are about 1/4 inch long
those marks are the rollers trying to move the paper. check to see if your tray 2 is lifting.if it is then replace the feed rollers.
Sep 28, 2009 | HP LaserJet 4mv Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
HP LaserJet 2100 Printer Logo
268 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
