Question about RCA RC926 Wireless Phone Jack
Instructions rca 940 wireless jack
Base unit light green extension unit light red cannot get them to sync together please help
5 Suggested Answers
SOURCE: We have the RCA 25423/24 base unit and we have
took the system back and bought a different system
Posted on Oct 02, 2009
  • 4 Answers
SOURCE: green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Posted on Nov 25, 2009
jyackle5
  • 8197 Answers
SOURCE: Base unit lights up red
Aorry we can not help you with your problem
Posted on Dec 20, 2010
SOURCE: My rca whp141 doesn't seem to work with my Sony 32
Press the menu button from the remote, look for "Settings". You should have a "Sound" category. Once you've located that, press Enter to go into the submenu. You want to look for "Audio Out" option and change it from the default "Variable" to "Fixed". Then you should have sound in your headphone. You can just either mute or lower the volume of your TV. Hope this help.
Posted on May 15, 2011
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I got a pair of RCA wireless headphones I want to use with this tv but can't find a jack to plug them in....help
You should be able to plug the base for the headphones into the Red and White AUDIO OUT jacks in the back of your tv.
Then make sure the base unit's power adapter is plugged in and it's turned on.
Then lift the headphones out of the cradle on the base and make sure they are turned on and the volume is turned up.
Good luck and post back if this helps or if you're still having trouble.
Jan 28, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Is it compatible with an IPCC nortel network phone?
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
Jun 02, 2009 | Plantronics CS60 Wireless Headset
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
My GE instajack is not working. It had a greeen signal, now it has a red signal.
Most likely, the extension unit cannot communicate with the
indicator light is solid base unit for one of the following reasons:
red • Base unit has yet to be installed. Install base unit. (Refer to
the Set Up section.)
• Extension is too far from the base unit. Relocate either the
base or extension unit to another electrical outlet. If
indicator light on extension
unit remains solid red, reprogram the link code on extension
unit
Follow these steps:
• Press and hold the button on the right side of the base
unit until the indicator light changes to solid red.
(Approximately five seconds.)
• Release the button, then the indicator light will blink orange.
This creates a new link code and places the base unit into
program mode.
• Follow steps (2) and (3) in the Additional Extension Units
section for all extension units.
• Press and release the button on the base unit to take it out of
program mode. The indicator light will change from flashing
orange to solid green.
Oct 10, 2008 | Computers & Internet
PHILIPS HEADPHONES SBC hc 8440
Hi there!
OK I know it is little late to response but if someone will google it, might find the solution, they are still selling it though. I just got my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small power in it, however you have to charge it. So connect the small charging cable into the base unit and the headset and make sure the switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity supply. Connect the audio connector from the base to the e.g. TV, PC, DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have two of the same wireless sets. So if on the base is set to # 1 the headset needs to be also on # 1. Then if you have second headset choose channel # 2 on the base and also on the headset # 2, so they are not crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
Hope it was helpful.
Michal Bohucky
Jun 01, 2008 | Audio Players & Recorders
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Apr 27, 2008 | Lands Phones
RCA RC926 Wireless Phone Jack Logo
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
