Stx 1100 HAVE A 2000 1100 STX DI 1100CC 130HP TRIPLE FICHT DIRECT FUEL INJECTION WITH ONLY 45 HRS ON IT. AT FIRST HAD FUEL PROBLEM, RESOLVED INJECTORS ARE OK TOOK OUT AND ADJUSTED THEM NEW SPARK PLUGS, AFTER ALL OF THAT IT STARTED AND RAN. HAD HOSE WITH RUNNING. COUPLE OF DAYS LATER WOULD NOT START. I KNOW MOST MECHANICS AUTOMATICALLY SAY ITS THE EMM. TOOK TO A DEALER HE TOLD ME HE HAD A CHECKER AND IT WOULD SHOW A CODE AND WE WOULD KNOW THE PROBLEM. I CALLED HIM AND HE SAID I WANT TO WORK ON THIS A LITTLE MYSELF I WILL NOT CHG YOU ANYMORE THAN THE $90.00 TO CHECK ON MY CHECKER. HE CLAIMED HE GOT IT STARTED IDLED GOOD. A LITTLE LATER HE TRIED TO START AND THERE WAS NO FIRE. HE SAID I HAVE A COMPUTER I WILL PUT IN AND WE WILL KNOW FOR SURE. THREE DAYS LATER I CALLED HIM BECAUSE I HAVE A BUYER FOR MY SKI,BEFORE I RAN MY AD IT WAS OK. I ASKED HIM WHAT DID YOUR COMPUTER SHOW HE SAID THE COMPUTER I HAVE WON'T FIT YOURS I THOUGHT IT WOULD BUT WRONG ONE. HE DID NOT HAVE A CHECKER AT ALL, I WAS A LITTLE YOU KNOW WHAT TO SAY THE LEAST. I HAVE HAD 4 MORE EMAILS ASKING ABOUT MY SKI. I WENT TO KENNY O AND SOMEONE WROTE HIM WITH SAME PROBLEM. NO FIRE. THEY CHECKED EVERYTHING. KENNY THOUGHT IT WAS THE EMM, GUY BOUGHT ONE BUT STILL NO FIRE, HE THEN HAD HIM CHECK THE STATOR, THAT WAS THE PROBLEM. I AM HOPING THIS COULD BE MY PROBLEM. I DO NOT KNOW WHERE THE STATOR IS LOCATED TO CK OUT. CAN YOU HELP ME OUT. I AM TOLD DO NOT PUT IN A REBUILT ONE, HOWEVER, ONE FORUM SAID TO USE I BELIEVE DI CO, HAVE WRITTEN DOWN SOMEWHERE. WHAT ARE YOUR THOUGHTS AND SUGGESTIONS. I KNOW I CAN GET $3,500. I AM IN MY EARLY 70'S & THE ONLY ONE THAT HAS RIDDEN MY SKI EXCEPT MY SON THAT IS 52. NO KIDS HAVE WRITTEN IT. I HAVE MAINTAINED IT WELL. KEEP ON A LIFT, AND WHEN LAKE IS TO LOW TO RIDE I GET HOSE AND RUN WATER AND START IT SHORT TIME. I HAVE HAD IT UP TO 59. DID RUN GREAT. I AM SICK OVER THIS. IT LOOKS LIKE NEW. I AM AWARE THE EMM WAS A PROBLEM WITH THIS SKI. KENNY O ALSO SAID THIS MODEL ALSO HAD SOME PROBLEMS WITH STATOR, THAT WERE MFG IN MEXICO. I AM MOVING FROM LAKE. SURE WOULD APPRECIATE YOUR HELP BILL
SOURCE: When i use my web cam everything shows up green.
Well, I tried everything on this list in a matter of 5 minutes. Nothing worked. Then I made the old DSL modem analogy.
Plug in your camera.
Right click on My Computer, go to Properties.
Go to the Hardware panel, and click on device manager.
Find your camera listing in there (probably under imaging devices).
Right click on it, and select uninstall.
Unplug your camera and then replug it in.
Worked for me. Of course, take SilverDragon's advice before mine - you don't want to be configuring the wrong device for hours and not getting any picture at all.
-Moin
Posted on Jul 15, 2008
Diesel13
  • 11 Answers
SOURCE: 1995 Chevy Cavalier 2.2L Automatic
Check your egr vavle. i had this problem with my old cavalier and it was as easy as removing it and cleaning it. It's probably plugged up with carbon
Posted on Aug 27, 2008
SOURCE: Misfire
One question, have you replaced the ECTS (Electronic Cooling Temperature Sensor)? These cause no end of different seemingly unrelated problems on Saturns. Peice is about ten bucks and is an easy install. Just search on youtube for a how-to video. Even if that's not the problem it is reccommended to replace this peice just the same as they ALL end up going bad at some point.
If that's not a fix, start pulling plugs. Check to see if they're correctly gapped and if they have any damage/corrosion. If you're running Platinum plugs, immediatly change to a copper plug as Platinums have no place in these motors. Most people have the best luck with NGK copper.
Check to make sure that your plug wires haven't been crossed. This sounds like a plug or wire issue most likely so it has to be in that family, if the plugs are good, wires good and not crossed, sensors are fine, then time to replace your coil packs. If you've replaced everything up to the coil packs then that is most likely the cause of your dillema.
Posted on Oct 25, 2008
jmeyer847
  • 204 Answers
SOURCE: 2003 Yamaha R1 not charging
Stupid Question but are all your wires clean and tight connections? Also make sure your batt ground is good too. R1's can be picky like that.
Sincerely,
JC
Posted on Nov 15, 2008
yooperbud
  • 8637 Answers
SOURCE: Please check that your camera is not currently in use......
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 15, 2009
My Evinrude Ficht 200 fuel injected, while running above 200 RPM has no problems but when idling the no oil alarm goes off and there is plenty of oil in the tank.
Its the oil sensor in the oil tank...does the oil line bulb stay pumped tight? If not. you need to do some investigating...or replace the bulb and line..
Jun 21, 2017 | Cars & Trucks
My 2000 Isuzu nqr cranks over great but wont start,i'm getting fuel to the filter but not to the injectors
big NQR TRUCK what model NQR 200, 300, what?
. what displacement engine, how many cylinders.?
Diesel right they only had gas in 1995 i think,
so is it direct injection (fuel rail direct?)
there are over 12, model H engines. 4Hxx all 12 are DI direct Inj.
so DI engines, have a ECU that injects. (much like modern gas engines,and huge injector pressure. , compared to port inj.)
so
  1. check fuses first.
  2. scan the PCM yet. ? that is 2nd, and mandatory.
  3. fuel pressure good (tricky on Direct injection read the FSM yet)? Some engines have sensors here to see pressure, scanned
  4. the PCM needs crank signals to inject. and reports them if bad.
  5. the glow plugs work? i check voltage then use my current meter amp clamp tool to be sure all suck spec, current, if not fix that.
post real engine names.
and country
or google, "diagnosing direct injection"
Apr 16, 2015 | Isuzu Cars & Trucks
Dose a 2000 taurus lx have a single or dual port fuel injection and is the coil pack for one cylinder or is it a pack for all cylinders?
depends on the type of engine. DOHC engine has coil on plug ignition system where the OHV has a coil pack with spark plug wires going to it. Both engines only have one fuel injector per cylinder.
Jul 13, 2011 | 2000 Ford Taurus
Need to know does a 1999 cherokee have indirect fuel injectors?
MOST PASSENGER VECHICLE FUEL INJECTORS INDIRECT.THE BIG DIESEL TRUCKS HAS DIRECT FUEL INJECTION SYSTEM.FUEL IS INJECTED DIRECTLY IN THE CYLINDERS.
Mar 05, 2011 | 1999 Jeep Cherokee 4WD
Where would i locate the fuel filter on a 1999 Ford taurus Se at?
Fuel Injection
General Information (System Description)
Electronic fuel injectors for all gasoline engine applications are basically
the same. They consist of an injector body, an electric solenoid, spring, nozzle
and a filter. The injector is supplied a constant supply of pressurized fuel
from the fuel system. The primary function of the fuel injector is to atomize
gasoline into the surrounding air at the proper time. Throttle body injectors
atomize fuel into the intake manifold in much the same manner as a conventional
carburetor (wet intake); port fuel injectors direct the atomized fuel at the
back side of each cylinders intake valve(s) (dry intake). Gasoline direct
injection systems operate at substantially higher pressure and direct the
atomized fuel directly into the combustion chamber of each cylinder.
Az Filters/Fuel Filter
Part Number:
FF679
The Fuel Filter is located: Under vehicle, passenger side, below seating area, passenger side of fuel tank, mounted on frame in fuel line
Oct 28, 2010 | Ford Taurus Cars & Trucks
Locate carborator on Chevy cobalt 2005
The 2005 Cobalt is fuel injected. It does not have a carburetor. If you are looking for the fuel injector it will depend on if it is thorottle body injected or direct port injection. Typically they are throttle body fed cars. Follow the air cleaner box up and the aluminum .housing will have the fuel injector in in.
Sep 11, 2010 | 2005 Chevrolet Cobalt
Injector control pressure sensor circuit low
I can't remember that year exactly so help me out it's been a while
is that a IDI diesel that has a injector pump sitting in top center front of engine (has all the fuel lines running off it) or is it a Direct inject engine that has the injectors all comming off a central fuel rail
IDI diesel = sensor is on pump front lower under cold throttle kicker coil
direct inject= sensor is on driver side at end of fuel rail toward fire wall
Apr 01, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
Computers & Internet Logo
David Payne
David Payne
