Question about Kyocera FS-6525MFP
Recently something happen to our machine the model is FS 6525 where a word appears from the screen says "Cassette Failure" I can not photocopy/print by placing the paper at the cassette while rite now Iam using the Bypass. I really need your help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
The tray broke check the tray and motors
Posted on Aug 18, 2014
4 Suggested Answers
  • 25 Answers
SOURCE: Kyocera FS 4000 cassette error
under the front of the cassette on the bottom is a white catch if you pull it towards you the paper will spring up. more then likely it is not automatically getting pushed when you put the cassette in.
if this is not correct if you take the cassette out and look in where you took it out of there should be a arm hanging down just left of center that is the paper out sensor arm of that is broken it could be your problem also
Posted on Jan 07, 2009
  • 62 Answers
SOURCE: Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Posted on Jul 07, 2010
Prefab
  • 152 Answers
SOURCE: need 2 cassette lift springs
Hello, the parts you are looking for is called the Spring Bottom Part Number 302F809010.
They may be hard to come by, A Kyocera Printer Dealer may be able to purchase them from the Kyocera Parts Dept. Use this link to find a dealer within the USA http://usa.kyoceramita.com/americas/jsp/Kyocera/wheretobuy.jsp I hope this helps and good luck with your parts search.
Posted on Jan 15, 2011
Error code - Different paper size is set. Check paper size
turn the dial on front of paper cassette to match paper size in the cassette
Mar 04, 2015 | Kyocera FS-2100DN Laser Printer - FS2100DN
How i do fix code error 245 for kyocera 6525 MFP
Upgrade to the latest firmware of the FS-6525MFP.
Oct 20, 2014 | Kyocera 6525 Copier
I have a Kyocera FS 6530MFP and when its in operation (during photocopying or printing), multicopies, it suddenly pops up an error on the display with the message ' cassette error ' , and abruptly sto
The cassettes have little motors on them that lift the paper up to the rollers when it's closed. Make sure there isnt a bind on the plate that lifts the paper up. If there isn't you might need a lift motor replaced. This is a pretty common issue.
www.equipmybiz.com Skelton Business Equipment Houston Copiers
Aug 05, 2014 | Kyocera Office Equipment & Supplies
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
Cassette failure
sometimes the lifting carriage not position than comes cassette failure.Please check the cassette box
May 29, 2014 | Kyocera FS-6525MFP
Kyocera fs 3920 dn printer ripping paper when it prints
Hi, dear; it have to be something stuck in the paper path, do following way; make a copy after 2 second stop the machine,pull out the paper,see there have been rip on the corner, if yes check that area, if not do next copy after run for 4 second , stop the machine, pull out the paper check it again until you found out the rip happen, the paper chip should be there. good luck
Aug 31, 2012 | Kyocera 1102J12US0 Model FS-3920DN Small...
Kyocera fs 1920 installed on windows 7 64 bit cassette 2 not showing
Download the KPDL drivers and after they are installed go to the printer properties, then device settings and select how many paper feeders you have "in addition" do the 1st tray. So if you have two trays just pick "one" for that option. Then you will be able to scroll back up and choose what paper type it is.
Lastly, set your Printing Preferences in the properties if you want to specify a specific tray/cassette to print from or just let the printer auto select.
Jul 27, 2012 | Kyocera Mita FS-1920 Laser Printer
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Kyocera FS-2020D won't print
You have to go to setting to change the cassette paper size , what happen is : in the setting that cassette has different size value, so when you try to print A4 it ask you to load it in the bypass or the Mp. all what you have to do is: go to cassette setting or comon setting and change the cassette siz to A4, and it will fix your problem.
Thanks for using Fixya
Oct 08, 2009 | Office Equipment & Supplies
A new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Kyocera FS-6525MFP Logo
362 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
