Question about Samsung LN40D550 LCD TV
Image shaking, foggy and looks kinda like static
I was watching TV, perfect image, then the image just started shaking looking like static. Is this something that can only be fixed by a professional?
    Top Expert:
  • Samsung Master
  • 73,710 Answers
It will be best to contact any service technician in this case. Gopakumar Gopalan Google
Posted on Apr 20, 2014
SOURCE: picture has a blur image
i think the problerm is not your tv but the reception on your free view
Posted on Aug 26, 2007
SOURCE: image is grany every time tv is cold.
I had the same problem. Except mine never got better after the tv warmed up. I fortunately I still have my manufacturers warranty and Samsung sent a guy out within a few days. He replaced a few parts which really didn't do anything. However what he did that was interesting was on two circuit boards. One on the mid left and the other on the mid right. Apparently there is a nob or something he tweaked on each panel that cleared the grainy image right up. What he told me was that the it is basically pixels that are not turning off in sync. adjusting the two circuit boards syncs the pixels to turn on and off at the same time.
Posted on Nov 12, 2007
  • 5 Answers
SOURCE: Samsung LCD TV Image Retention...I Think
Sounds like a defective set. I have the same TV and don't have this problem. It's a long shot, but one thing you could try is turning on "Game Mode" which is designed for fast moving action.
Posted on Jul 15, 2008
  • 12 Answers
SOURCE: Snowy with blue and black squares
your va and vs need to be adjusted and if that doesnt fix it then you have a board going bad but still requiers repair or service tech to find out
Posted on Feb 07, 2009
  • 98 Answers
SOURCE: I have a Samsung plasma hpn5039, and i was
Two things,
1st -- power board problem
2nd -- Y- Main Board problem
If you are familiar with TV,
Open the back panel first then check the fuse on power & Y-main
Board.
It had problem that the board's which disconnected fuse on.
Posted on Feb 24, 2009
When CRT JVC TV is first turned on, the image looks shrunken and warped, eventually, the image looks fine. What to fix?
SMPS fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Check all the electrolytic capacitors.
May 26, 2014 | Televison & Video
Bose Lifestyle V35, sound but no image.
Thank you so much the unplug the power from the system worked after hours of trying other stuff
Huge thank you
Aug 14, 2012 | Bose Lifestyle V35 Theater System
Picture is shaking during live events
If its just live events, I'm going to assume its your cable/satellite provider. If you watch blu-ray, DVDs and it doesn't shake your TV is fine.
The first step is to determine whether it's the LCD display, the image or the video feed from your cable or satellite provider. Make sure all your connections are secure and not
To test the LCD display, open your menu options to see if that shakes. If it doesn't then it's not a hardware problem and your TV is fine.
If your menu does shake, unplug everything from the TV. You will need to test if you have possible inference from other devices. One by one plug your devices in and view the menu for it to start shaking. This is one possible solution to the shaky image.
Again, other possible solution is your cable or satellite providers feed is shaky. You need to call them and inform them of the issue. A replacement receiver could solve the issue.
Jan 07, 2011 | Televison & Video
The screen on my tv has two slightly discoloured vertical bars
Sounds like image retention. Is it an older Plasma TV?
Image retention is when an image left is left on for a while actually "burns" into the image. It would be especially noticeable in BluRay because it is a bright image. The burn in was probably cause by watching Cable in 4:3. Try to find a static white image to display over night that should remove the burn in.
Nov 25, 2009 | Samsung Televison & Video
Purple and Green haze on television image
Do you have any speakers near the TV, that aren't shielded... ?That's kinda what it sounds like to me.
Apr 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
The image expands off the screen of my HD tv
Look in the menu for an image adjustment option. This is used to center or adjust the given image. Try a different type of connectiong from the cable box to your TV. ie; if you are connected by component connection, try AV or HDMI to test. If that doesn't work, look at the cable box settings (call your cable company for instructions) or have the box replaced if defective.
This is common for PC connections but not for cable.
Dec 21, 2008 | Televison & Video
Fogging problem (i.e.) screen is foggy at start up but clears 20 to 30 mins use.
what is model number of your Sony tv to provide you info about foggy picture problem.
Oct 05, 2008 | Sony XL-2100U Projector Lamp for...
Whats wrong with my viewfinder?
I don't have my camera with me, so I may be off on the exact placement, and I hope I'm not telling you something you already know and the problem is worse, but on the left side of the viewfinder itself is a tiny dial that adjusts the focus. Just look the the viewfinder and play with the dial to adjust to your eyesight.
Apr 03, 2008 | Canon PowerShot S3 IS Digital Camera
Samsung LN40D550 LCD TV Logo
77 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
