Question about Jabra Stone Bluetooth Headset
How do i change the language setting on my Jabra stone 2 device?
5 Suggested Answers
  • 10865 Answers
SOURCE: I have a Blackberry 9000
Hello. The jabra stone is one sweet device with a history of pairing problems. IT is capable of being paired with two phones at once but I suspect that yours is now in pairing limbo because of that. Do this. phone their techs, the number is here: Phone:
1 (800) 327-2230 (U.S)
1 (800) 489-4199 (Canada)
They may have to talk you through a factory reset. Joe
Posted on Oct 25, 2010
EdNelson
  • 149 Answers
SOURCE: I have tried everything in
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 04, 2011
  • 149 Answers
SOURCE: i am having trouble pairing
Hi, Look for "Add new device". Hit OK.
the phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
I've reviewed Bluetooth headsets before, and I would have to say that the Jabra STONE is one of the sleekest looking. Its shape is designed with minimalist simplicity, with a shape made for either the left or the right ear.
This shape goes onto a charger that is perfectly made to accept the Jabra STONE like a puzzle piece. This charger is probably what sets the STONE apart from most Bluetooth headsets, as it can charge the headset as the user goes. A green indicator means that it has enough charge for one full time or more. The red indicator means that it needs to be charged.
The STONE can be charged with an AC cord or USB connection. Once it is charged, there is a pairing indicator that made it simple to sync with my mobile phone. It has about 12 days (288 hours) of standby time and 8 hours of talk time.
I found that pairing the STONE with my phone was quite simple. In a matter of seconds, it was connected to my phone and I was making my first phone call on it.
The sound for the STONE is pretty good, with dual microphones and their trademarked Noise Blackout Extreme and crystal clear sound and voice with DSP.
One of the big features that I found is the touch sensitive volume control. In other words, there is no buttons for controlling the volume. I welcomed that, and most volume controls on Bluetooth headsets are really, really tiny buttons.
Other features include the ability to connect to two devices at a time, and it can stream music from an A2DP enabled mobile phone.
This is the problem that I had with the STONE. I found that there isn't really a "standby" indicator. I found that using it was a hit or miss situation. If I just pulled it out of the charger, it would sync with mobile it would work. When my phone rang later, and the headset was out of the stone cradle, and hitting the "connect" button didn't help. In short, I had to answer my phone. The Jabra STONE failed me, but I remember having similar awkward experiences when I first used other Bluetooth headsets.
The Jabra STONE comes with the headset, charger, 2 Eargels, a belt clip, AC charger, and a USB charger. You should be able to get it on Amazon for about $90 as the price to this writing.
Posted on Feb 24, 2011
Testimonial: "the information posted was very helpful...i was able to finally get it working using this solution... thanks! "
SOURCE: the jabra stone device will
Depending on the phone, Some phones need to be set to be visible so that Jabra can find it when it is ready to pair.
I would delete the paired entries on the phone and do a fresh pair to the phone.
Do let me know if you are able to do this or can chat and walk you thru.
Posted on Mar 01, 2011
How to change language from german to english
You need to download english version from Jabra Support web page and install it.
Mar 08, 2014 | Jabra Stone Bluetooth Headset
Error 9119, 9114 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Dec 29, 2012 | Rosetta Stone Computers & Internet
It connects has volume but i get no sound at all, how do I repair?
I can' t hear any Songs from laptop to jabra Stone 2,
Despite the success of contact and the name of the handset appears on laptop
Jun 21, 2012 | Jabra Stone Bluetooth Headset
Dont no how to pair order on ebay no hand book
this is for the stone 1
http://www.jabra.com/sites/mobile/na-us/support/pages/pairingguide.aspx
this is for the stone 2
what phone are you trying to pair with the bluetooth headset?
the default codes for jabra headsets are 0000
Mar 01, 2011 | Jabra Stone Bluetooth Headset
The jabra stone device will not pair with my mobile phone. It was paired at one time but has since quit working.
I am having trouble pairing the Jabra Stone with my iPhone 3gs. I have held down the stone button multiple times and nothing happens. Also i have turned it on and off multiple times, but it just wont...
Feb 24, 2011 | Jabra Stone Bluetooth Headset
I have tried everything in the manual to pair it with my iphone 3GS 4.1 but it's still not pairing. The iphone is looking and looking but doesn't find the device. Even turning the jabra stone of and then...
Dec 15, 2010 | Jabra Stone Bluetooth Headset
How to configure keyboard in Rosetta
you can press SHIFT+ALT to change keyboard language
Also verify in control panel - regional and language options , languages tab, at details if is installed new languages for your keyboard
Aug 04, 2009 | Rosetta Stone Japanese Level 1 & 2 for...
Jabra Stone Bluetooth Headset Logo
57 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
