Question about Juki Sewing Machines
Juki mo2512n upper looper part number - Juki Sewing Machines
2 Suggested Answers
SOURCE: Juki 6700 looper number
lower looper part no.: 119-99307
upper looper for 3 thread and 5 thread : 118-88104
upper looper for 4 thread : 121-76004
Posted on Nov 12, 2010
HOW CAN I BUT THE THREAD OF JUKI MACHINE 3 THREADS
Search the internet for a manual:
Make + Model + the word "Manual"
or contact the manufacturer support group.
FWIW, be sure to RAISE the presser foot when threading, and thread each thread in the proper order (usually the upper looper first, lower looper second, etc.) and confirm the thread path for each thread. Give each thread an extra little tug when going through the tension disk to make sure it is seated all the way.
Start out with the tension disks set at the midway point between high & low numbers. This is the standard setting for an overlock stitch, however, each machine may need a bit of tweaking to get the stitch right.
If a thread breaks, it's usually because it has been threaded incorrectly.
Apr 03, 2016 | Juki Sewing Machines
Just bought Juki MO1000. Have threaded and re-threaded several times (easy enough) because the lower looper thread (position 1) thread breaks after sewing 4-5 inches. Any ideas?
Yep, 9 times out of 10 when thread breaks, something is not threaded correctly. Also, whenever thread breaks or becomes unthreaded, best policy is to unthread everything and start over from the beginning. Simply re-threading the broken thread will usually not work.
Remove all the thread from the machine. RAISE the presser foot (important to ALWAYS do this so the threads will seat properly in the tension disks).
Rethread totally from the beginning making sure to follow the threading instructions for each thread and that the threads are threaded in the ORDER (ie upper looper, then lower looper, then needles) per the manual. If the threads are not threaded in proper order, the machine will most likely never work.
When threading the lower looper, as the last step, be sure to pull the thread tail over the top of the upper looper mechanism before pulling the thread tails under the presser foot.
If the thread continues to break, make sure the tension for that disk is not set too tight. Loosen it up and see if that makes a difference. Most factory standard thread tensions are around the midway point between the high and low numbers. Then slight adjustments can be made from that setting to tweak the tension result.
Jan 29, 2016 | Juki Sewing Machines
How to threat a juki mog2516n
Stand in front of your machine and shake your fist vigorously. That's how you "threat" a machine.
Your JUKI has a thread guide inside the front door. Open that and follow the colors... Upper looper, Lower looper, right needle, left needle.
Sep 03, 2012 | Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
Juki skipping stitches
completely un-thread the machine and rethread it in this order.
Upper Looper, Lower looper, right needle Left needle. It has to be in that order ALWAYS. If you break a thread... un thread and start the threading process again.
If rethreading doesn't work... change the needle that is skipping.
Good luck
Aug 16, 2012 | Juki MO6714 Mechanical Sewing Machine
Mo-3616,class=FH6-60H model upper looper parts number?
HI THERE
PART NO. FOR THAT MODEL IS ( 124-81206 )
THAT UPPER LOOPER FOR EXTRA HEAVY MATERIAL.
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
Feb 15, 2011 | Juki TL-98Q
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
Sep 28, 2009 | Juki Sewing Machines
THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Jun 27, 2009 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
