What is my ip address port
I need the port number for ip 192.168.0.2 where is it found? something about it being on my panel......
    Scholar:
  • 84 Answers
If you are trying to edit the settings, it would likely be port 80
Posted on Apr 21, 2014
  • 84 Answers
SOURCE: factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
Posted on Feb 11, 2008
SOURCE: port forwading
http://portforward.com/
this site may be of some assistance
Posted on Jun 19, 2008
SOURCE: cannot acess ip address
HI! you can access the ip address of your router by connecting it directly to your computer.. if you are using a windows xp operating system. use your mouse and click on start and select run, from there it will show a box and type in on the box cmd and it will show you a dos prompt and from there just type ipconfig /all and it will show your ip address..
Posted on Jul 25, 2009
  • 159 Answers
SOURCE: Netgear DGN2000: Only ethernet port 1 works.
Sounds like a configuration issue. With some routers you can set them up for bridging. Normally port 1 would connect your "bridge" and port 2-4 would connect your computers. You can test this by plugging your modem into port 1, and your computer in port 2. Power cycle your router and see if you get connectivity. It may be in your best benefit to reset the router to factory settings and see if 2-4 work with factory settings. After the reset, reconfigure the wireless side and your firewall.
Posted on Oct 26, 2009
puertobori
  • 7733 Answers
SOURCE: Need default IP address for Linksys Model NR041 4
go Lynksys Support and Services.
Posted on Oct 27, 2010
Need to know wat ip number is and port is
IP stands for Internet protocol.
It's represented by numerical code, which is assigned to each device like computer, printer, phone.
IP's are two types. There are Internal IP, External IP
Internal IP means that your system ip address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system ip address
External IP address means that your network IP address. If you want to know your Network IP address then visit IP-Details.com here it display IP address, ISP,location, Longitude, latitude and so on.
To find your port number follow these commands:
Go to start--->cmd---->type netstat -a
Feb 02, 2014 | Televison & Video
How to convert local ip camera addresses to ip addresses to connect from internet
depend on what brand and type of the ip camera that you use.
in order to be able to access from internet:
- you need to use a router that connect to a switch and the camera
- the router must have UPnP Feature & Port forwarding.
- just in case your public ip address is dynamic, you will also need a ddns for redirection.
The basic concept is, you have to configure the network setting of the camera according to the router as a gateway.
usually, in the network setting, you will find a http port number.
change this number from default ( 80 ) to another number from 0 to 65535 ( example 50010 or 40000 , you can choose freely, it's recommended to use port above 50000 )
then find the portforwarding function in your router, then set the port number to the ip address of the ip camera.
if it's successfull, you can directly access the camera from the internet by entering your public ip address and the port number on your browser.
for example : http://itcomm-streets.viewnetcam.com:50001 << my ip camera demo unit.
Jul 02, 2012 | Android Apps
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
I have changed my router and my networked printer no longer works
Hello Warren !
What happened is that when you replace the router, the IP Address for your printer changed as well. Your network printer connects to your computer through a number called the "IP address" wich is assigned by your router, since you replace your router, the new router assign a new Ip address for the printer, so you will need to change that IP address on the printer driver on your computer as well.
What you need to do is print a configuration report directly from the printer to figure out what the new IP.
When you have this number ( it will look something like "192.168.0.1")
you need to go to "printer and faxes" under control panel, make a right click on the MFC-465 icon, go to properties, then go to the ports tab a click on "Add Port" select Standard TCP/IP and type in the new ip address.
This should reentablish the communication between your printer and computer.
Good Luck
You can contact me directly here:
eliteprintersolutions@gmail.com
Jul 15, 2010 | Brother MFC-465CN InkJet Printer
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
How do I do port forwarding with one static IP to put my address in my other computers . I need to shadow into with VNC after I install address on my computer is port forwarding marked on the menus are...
Find the IP-address of the computer that you want to accept VNC connections.
Access the router's web-interface.
Find its web-page for "port-forwarding".
Define 'TCP' port '5900' to be forwarded to the IP-address that you found.
Save the settings, and restart your router.
Hopefully, Verizon's FIOS network does not "block" all 'TCP:5900' traffic.
Nov 17, 2009 | Linksys Computers & Internet
HP Laserjet 4050Tn can't be found by network computers (XP)
To install the HP as a network printer you need to do the following -
1. Configure the HP's IP address so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer to the network hub/router and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standart TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to setup the HP printer the same way on every computer on your network.
You can now print from any computer on your network
Sep 02, 2009 | HP LaserJet 4050tn Printer
Can't play Starcraft...
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Jun 23, 2009 | NetGear RangeMax WPN824 Router
Need IP address for Dell 5100cn printer
You will need to print off a printer settings page. Usually found under the Reports menu or something similar. It will list the IP address. Once you have the IP Address, make sure it is set correctly in your printer drivers in the Control Panel on your computer.
May 26, 2009 | Dell 5100cn Laser Printer
Ip address
Open the control panel for your router and look at the set up page. You will see
Starting IP Address: document.write(document.setup.SDHCP1.value+"."+document.setup.SDHCP2.value+"."+document.setup.SDHCP3.value+".") 192.168.1. X x being the starting number. The first number is the first port on your router.
Feb 19, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
