Question about Onkyo TX-NR626 7.2 Channel Network A/V Receiver with 4k Video Upscalin
Finding the permanent loop on the onkyo tx nr626
Wheres the loop for external equalizer (behringer fbq1502)
5 Suggested Answers
  • 6 Answers
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
Posted on Nov 29, 2008
dunnbiker
  • 8546 Answers
SOURCE: Graphic equalizer
In general all equalizers, being designed to be in a Tape Monitor loop, have the option to Equalize either the Source or the Tape or nothing. Check for that control and toggle it. My old ADC SS-525X has pushbuttons whose settings (Tape/Source) are not easily determined. I always have to play around with it to know which is selected.
I'm betting your EQ is processing the program that would head out to an attached tape deck.
Posted on May 18, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Posted on Aug 28, 2009
c1apton15
  • 3400 Answers
SOURCE: can i connect a graphic
sure... externally from speaker leads.
Posted on Jan 30, 2011
Behringer FBQ1502
An old trick we use to do is use the TAPE IN/OUT of the receiver and hook it to the stereo RCA IN/OUT of the equalizer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Behringer FBQ6200 Home Equalizer
HOW TO CONNECT A ONKYO TX NR535 TO AN EQUALIZER
First this solution will be fraught with potential problems:
1. There is no simple monitor outputs and inputs on the NR535.
2. The NR535 analog inputs/outputs are unbalanced, where the Behringer EQ is completely balanced (TRS or XLR)
3. Insertion of the EQ is analogous with inserting an effects device in an audio loop which in the case of analog surround will cause de-correlation or the companding sidechain making for non-compliance/performance issues.
OK, now the solution can be as follows:
Since the NR535 has a Zone 2 channel, you can use these L/R RCA outputs to make an effects loop. To do this you will need to make or buy RCA to TRS (1/4" phone Tip Ring Sleeve jacks) that you will connect from the Zone 2 outputs to the CH1 and CH2 inputs of the EQ. You will need another pair of the RCA to TPS to connect the output of the EQ back to one of the RCA analog inputs on the back of the Receiver.
Now once this is done, you will be able to Map Zone 2 input to any of the inputs other than the one you are using for the output of the EQ. Let's say you have mapped Zone 1 to your gaming station. This will patch the audio from your gaming station into the EQ and back into your previously connected analog input. At this point, you can leave Zone 2 and select your analog input which is your EQ output, which is your Gaming station. If you don't have any output, you may need to go back into the Zone 2 setup and adjust the volume level.
When you don't want the EQ in the signal chain, just select the input source other than the input used for the EQ's Zone 2 output.
I am not sure if this will work for all situations as you may have technical conflicts between analog and digital audio on some inputs. In any case, this will work with analog signals and I don't see any other simple solution for your case.
I hope this solution can help.
Feb 26, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
Onkyo tx nr626 when volume high like 70-80 it turn off sign check speaker wires
soundslike a shorted speaker or a speaker that is being over-driven
Jan 07, 2015 | Onkyo Tx-sr507 A/V Receiver
Manual behringer fbq 1502
you can download a manual at this link (it's a link direct to the manual, so you only to save or print it, it will appear on your screen)
http://www.behringer.com/assets/FBQ6200_FBQ3102_FBQ1502_M_EN.pdf
There is a quickstart guide also, on the page where I got the manual download from
http://www.behringer.com/EN/Products/FBQ1502.aspx
24.August.2014
Aug 24, 2014 | Behringer Audio Players & Recorders
How do I connect my behringer fbq1502 to my behringer professional mixer dx750.?
You have a sent and return http://www.behringer.com/assets/DJX750_M_EN.pdf
They explain it in the manual but the output from the mixer and between that the equalizer and the equalizer output to the speakers works great, not the tape..... they have a way lower S/n ratio and i've never heard of this solotion
Jun 19, 2014 | Behringer FBQ6200 Home Equalizer
Tx-sr575 7.1 - is there any use in connecting and old power amp and equalizer to this receiver? If so, how?
Ya mean like to hook up Bose 901's? Nevermind.
Utility is in the imagination of the dreamer.
http://www.retrevo.com/support/Onkyo-TX-SR575-Receivers-manual/id/2526bh749/t/2/
Any analog processor can occupy the Tape Out/In loop. However, it will only affect stereo analog sources and, once engaged to monitor, it will disable any digital audio source.
An external amp COULD be slaved off the tape Out (or the anticipated EQ Out, but it won't be volume-controlled by the Onkyo. You would need an AVR with at least Front L/R pre-outs.
Aug 12, 2011 | Onkyo TX-SR575 Receiver
That is not my product! Mine is FBQ1502! I cant use your info!
Hi again,
Thank you for correcting the model. To my understanding the FBQ1502 also uses ¼” TRS connectors same as the FBQ6200.
Aug 13, 2008 | Behringer FBQ6200 Home Equalizer
Hi...
Hi again,
Aug 12, 2008 | Audio Players & Recorders
Graphic equalizer
Nov 14, 2007 | Onkyo TX-8222 Receiver
Onkyo TX-NR626 7.2 Channel Network A/V Receiver with 4k Video Upscalin Logo
54 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
