Question about Dynex 32 in. LCD Flat-Panel HDTV
How do i change the tv to channel 4 for cable
    New Friend:
  • 3 Answers
You need the remote control from the cable company that should have come with the cable box. Or you can buy a universal remote and program it to your tv.
Posted on Apr 19, 2014
Can't change channels stuck on 4 tried scanning it but it goes back to 4
There could be a few possibilities for this .:
  • Change the "Input" setting on the TV to "AV" or "VIDEO". There is probably an "INPUT" button on the remote.
  • Find the TV/VIDEO mode on your tv or check the back of the cable box where your cables screw into the unit. There is normally a switch to select an output for channel 3 or channel 4. Your's would be on 3. It's just a matter of switching to 4 to make it work on your tv. More info on this here:
  • https://www.google.com/search?q=tv+channel+stuck+on+4&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
Jan 28, 2016 | Televison & Video
TV will not display picture or sound except for 1 station which appears to be 440. I can't change the channel either at the dials or remote. The display says EAS.
DONT USE the remote that came with your TV
use the buttons on the box to change the channel. did the channel change?
usually when someone only has one channel its because they are changing the tv channel not the cable box channel
think of it like this:
the TV is a monitor and should always be on the same channel (3, 4, hdmi, or whatever) its actually the box that tunes and the tv always stays on the same channel.
so if you change the tv channel you are no longer watching the output of the cable box.
USE the remote supplied by your cable provider
Aug 06, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
Why all my cables channels not working
if you are using coax cable to conn cable box to tv, be sure to use the analog ant conn on back of tv, and there is a switch on the back of the tv for selecting channel 3 or 4, for cable box use. be sure to turn tv to the same channel the switch is selected to, and always use the cable box to change channels/ programs, not the tv channel selector.
Feb 26, 2013 | RCA R52WM24 52" HDTV Projection Television
I cant get channel three to appear on my tv, to view the cable box channels. Please help I need to reprogram the channels.
You could go to the back of the cable box and change channel from 3 to 4 and use tv on channel 4
Oct 31, 2010 | JVC AV-32260 32" TV
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
Changing TV set up to cable from "air"
Try setting tv to channel 3 or channel 4, this should coincide with the back of satellite box (a little black switch with a 3 or 4). then switch channels with your satellite box. I would recommend using another output off the satellite box to feed the other tv, a splitter loses some signal quality an can go bad as well. get a long rca cable to feed tv!
Mar 01, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Snowy screen on tv
the 3 or for setting on the vcr is on the back( a switch)
or if the cable box has a channel 3 or 4 setting on the back of the box
but otherwise the tv may need some work on the tuner or need a new tuner
Dec 01, 2008 | Philips CCC130AT 13 in. TV/VCR Combo
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
Dynex 32 in. LCD Flat-Panel HDTV Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
